Fuel Pump Problem - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-06-2004, 10:34 AM   #1 (permalink)
Member # 3298
Fuel Pump Problem
I have an 76 AMC 360 in my CJ, the fuel pump for a 76 changed designs and will not fit on my engine (sits upside down now) and hits my power steering, so I cannot use it.
I checked and found 74-75 is the design I need. I put it on and when parked, I can rev the engine and gets plenty of gas. When driving, it seems it is starving for fuel, bogs down, some backfiring, then just let it sit a few moments and it goes back to normal. New tune up, timing is good, new edelbrock carb.
jeeprugger6 is offline   Reply With Quote
Old 01-06-2004, 01:34 PM   #2 (permalink)
Member # 17743
Location: columbus ohio on the weekends Toledo all week
Send a message via AIM to littlemule Send a message via Yahoo to littlemule
did you change the fuel filter and air filter?
if not then try that first, and what about the fuel pick up in the tank? is it in good clean order? those 3 could be some of your problem, if that doesnt work then I am not sure.
This aint my first county fair!!!
broncohio.com
74 bronco 5.0, 36 tsl, Just sitting there begging for a little love!
littlemule is offline   Reply With Quote
Old 01-06-2004, 07:31 PM   #3 (permalink)
pepe's Avatar
Member # 17870
I always suspect water in the fule this time of the year.
Arguing with a inspector is like wrestling with a pig in the mud.
After a while you realize the PIG is enjoying himself!
pepe is offline   Reply With Quote
Old 01-13-2004, 10:09 AM   #4 (permalink)
Member # 3298
TTT
Old 01-13-2004, 04:48 PM   #5 (permalink)
Member # 26083
Check your vacuum advance diaphram in your distributor.
All right you Mother Stickers, this is a Fuck up! Raise your Balls or I'll Blow your hands off!
Shades76cj5 is offline   Reply With Quote
