77 cj5 disc brake swap - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-01-2004, 05:04 PM   #1 (permalink)
Member # 26854
Hello. I thought I had my dana 30 disc brake swap all figured out. I needed was new hubs, rotors, calipers, caliper brackets and bearings. I have recently read on the net that I need the knuckles from a disc brake front end. Is this true? Could some one let me know before i rip her apart
Thanks
Jonny
jonnybc is offline   Reply With Quote
Old 02-01-2004, 08:46 PM   #2 (permalink)
CJeep77's Avatar
Member # 25458
In 77, disk was an option. My 77 had the 4-wheel drum plague too! The 6-bolt spindles will mount right over.
By the way, this is a noob question!.
AAH! I now see you are a real noob, as in numero uno! You need to go to the newby forum and read the rules to understand!
CJeep77 is offline   Reply With Quote
Old 02-02-2004, 05:42 AM   #3 (permalink)
Member # 26854
My question was not a newbie question. Maybe new to Dana 30. It is perfectly reasonable that different knuckle may be needed to clearance the rotor or caliper when going from drum to disc.
I have been doing this stuff for a long time. Too long to be considered a newbie. I just really wanted an answer if anyone had done this.
For someone that answers my knuckle question with a spindle answer and then hint that I am a dumb ass and that I need some instructions is kinda funny. How can it be a newbie question when you can't answer it? I did read lots of posts in the "non-newby" area and there are some very stupid questions. Not that I am criticizing anyone.
I understand not wanting the "How much lift do I need?" and the "I have 1000 bucks to spend" questions. But judging someone by the number of posts is ignorant.
Thanks
Jonny
Old 02-02-2004, 06:20 AM   #4 (permalink)
Mo
Everyday is Tuesday.
Mo's Avatar
Member # 47
a. you got your answer without needing a Nomex suit. Be happy. Swapping stock stuff is a newbie question. Be happy.
b.
Mo is offline   Reply With Quote
Old 02-02-2004, 08:56 AM   #5 (permalink)
Member # 26854
no I didn't you guys are all a bunch of clowns
Old 02-02-2004, 09:14 AM   #6 (permalink)
Member # 9614
You can go through the pissing and moaning of swapping knuckles, but it's not worth it. 5-10 min. with an angle grinder on each drum knuckle, the calipers will clear just fine, and the knuckles won't be any weaker than before.
EDIT: I should note, since you didn't mention which style of front brakes you were using, the above easy-peasy version will only work with the 77-79 6-bolt caliper bracket styles. Of course, since these are the only versions you should even bother swapping because they're stouter and use the better 6-bolt lockouts on the hubs as well, I took it as common knowledge.
Choose Life. Preferably Cinnamon.
[url]http://McBob.TV[/url]
fullygruntled is offline   Reply With Quote
Old 02-02-2004, 04:47 PM   #7 (permalink)
Member # 26854
Thanks thats what I wanted to know.
