Wiil toy front hold up to 35s locked? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-13-2004, 06:52 PM   #1 (permalink)
Member # 22010
I have an 81 toy I am building. I am on a budget though. Will I most likely break stuff in the front end with 35s and either welded or locker. I would like the extra traction, but don't want to keep breakin stuff. Oh yeah, the front end is stock and I will just run it that way due to money issues. Thanks.
01tacoboy is offline   Reply With Quote
Old 02-13-2004, 06:56 PM   #2 (permalink)
blacktoy's Avatar
Member # 22837
depends on the terrien you wheel and your driving style, most likely if you like to "get it" stuff will break
[URL=highvibesoffroad.com]highvibesoffroad.com[/URL]
blacktoy is offline   Reply With Quote
Old 02-13-2004, 07:53 PM   #3 (permalink)
Member # 234
Send a message via ICQ to toy283
Stock front end, dual cases, welded front diff, blown V8, 38" rubber, no breakage yet. Knock on wood...
Dave
'84 X-Cab, Supercharged 283 V8, SM420, dual cases, etc....
'85 4Runner
toy283 is offline   Reply With Quote
Old 02-13-2004, 08:06 PM   #4 (permalink)
Member # 22010
also will run 5.29s. I plan to run the rubicon, dusy, etc. I drive fairly easy, but don't exactly baby it along either.
Old 02-13-2004, 08:44 PM   #5 (permalink)
Member # 26524
Other than just being hard to turn you should be fine. Welded or detroit just keep doing your forearm exercises, cause by the end of summer you will look like Popeye.
CALIFORNIA CREEPERS
MDIZZLE is offline   Reply With Quote
Old 02-13-2004, 08:50 PM   #6 (permalink)
Member # 15343
depending on the circumstance pretty much anything will break
DIRT, MUD, ROCKS WHATEVER!!!!
Islandzuki is offline   Reply With Quote
Old 02-13-2004, 09:52 PM   #7 (permalink)
Member # 17610
You will be fine unless you really romp on it....and it depends where you wheel. Just be smart, don't climb things while turning super-sharp and don't climb backwards.
KK
www.crawlinaz.com/forum for AZ crawling and trail runs
85runnerAZ is offline   Reply With Quote
Old 02-14-2004, 09:01 AM   #8 (permalink)
Member # 14335
Send a message via AIM to sleepertoy Send a message via Yahoo to sleepertoy
ditto
I swapped in an 85 axle to my 91 toy (like many many other folks) I run 5.29s, longfields, dual t-case behind my 3.0 V6 and I'm on 35s. So far so good. I know a ton of us Toyota guys run this setup or one similar to it. People who are on serious rocks tend to break stuff but then, that happens even with the really tough axles and what not. Up here, I see fewer rocks but our true obstacles I would say are lots of rocks in the form of shelves with dirt before and after. I've yet to break any moving parts.
"No matter how slow the film, Spirit waits for the photographer it has chosen." -Minor White
___________________________________
sleepertoy is offline   Reply With Quote
Old 02-14-2004, 12:25 PM   #9 (permalink)
ROCKILLER's Avatar
Member # 3273
yea like he said, turning sharp is gonna kill your birfields, they are gonna be your main concern. other than that you should be ok
ROCKILLER is offline   Reply With Quote
Old 02-14-2004, 12:29 PM   #10 (permalink)
Member # 24837
should be fine if you play nice. i'd recommend some kind of super birfs at least though, as a precaution
kyle_22r is offline   Reply With Quote
Old 02-14-2004, 09:20 PM   #11 (permalink)
Member # 18487
Send a message via AIM to Tintop
Drinking = Breakage
Don't drink and Drive
Tintop is offline   Reply With Quote
