Motorcycle Shocks - Why NOT?!?! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-18-2004, 05:59 AM   #1 (permalink)
Member # 11372
Iīm posting this in the noob forum, so you fawkers wonīt be able to flame me...............
OK, so why COULDNīT motorcycle shocks be used on a crawler?!?
Capacity??
Shock absorbing characteristics??
Mounting??
Other??
Iīm thinking that any one of these problems could be overcome with a little work and could result in a decent coilover or even Fox Shox substitute for a fraction of the cost. All being equal, I plan to go with the Fax Shox, but Iīm just curious if anyone has tried bike shocks........
Remember fawkers, no flaming here in the noob forum........
Bill
Subi powered Beetle Buggy
billj is offline   Reply With Quote
Old 02-18-2004, 06:08 AM   #2 (permalink)
Member # 4382
Not valved for the weight, not enough travel.
indysand is offline   Reply With Quote
Old 02-18-2004, 06:12 AM   #3 (permalink)
says "yall" alot
45acp's Avatar
Member # 13671
not valved for the weight, not enough travel x10.
Hey kid, are you going my way?
Hop in... we'll have ourselves a field day
45acp is offline   Reply With Quote
Old 02-18-2004, 06:13 AM   #4 (permalink)
Member # 11372
Iīm thinking that valving could be modified. Length I donīt know for sure, but I recall seeing some pretty long motocross bike shocks.........
Just a wild ass thought anyways.........
Bill
Old 02-18-2004, 07:35 AM   #5 (permalink)
Member # 538
I've got a junked KTM in the yard with 14" travel in the front forks, but the spring rate and valving is very light - this thing only weighs ~200#. Maybe if you put four or more on each corner it'd catch on with the show-truck crowd.
Lloyd is offline   Reply With Quote
Old 02-19-2004, 07:35 PM   #6 (permalink)
THIS SPACE FOR RENT
dane's Avatar
Member # 21948
There is definitely not enough spring rate in the motorcycle suspensions regardless of valving. Also there isnt a way to get enough travel out of the rear shock to use for anything worthwhile. If you get in to the high end stuff that might be able to work you are spending waaaaaayyyyyyy too much money.
Dane
HOOLIGAN
ROCK
CREW
SEE WHAT THE HYPE IS ALL ABOUT:
http://www.facebook.com/hooliganrockcrew
I WILL TRY BEING NICER IF YOU TRY BEING SMARTER.
FU JS FU KS FU RTF FU FOTR FU DA FU RMK
dane is offline   Reply With Quote
Old 02-20-2004, 09:08 PM   #7 (permalink)
Member # 21888
valving really aint an issue, they can be valved and sprung to be perfect for buggy applications the problem is the shocks no matter how long still only have 3-4 maybe 5 inches of travel. The bike gets its travel cuz of the swingarm and linkage. So if your fine with a 4 inch travel shock build away, if your thinking of using the front forks that is just plain silly.
psychobilly is offline   Reply With Quote
