Noob welding question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-19-2004, 01:13 AM   #1 (permalink)
Member # 27028
Send a message via Yahoo to 73RustBucket
First of all I know zilch about welding. A guy I work with says he knows how to weld and would help me weld up a roll cage. We have been working on ideas over the last week or two. I would like to weld the cage directly to the frame. Is there any problems with the electrical system that I should know about before I let him torch it up? He is concerned that with the current used in welding the cage to the frame that it could fry the wiring. Is he crazy? Should I just pay the $$$ to have a welding shop figure it out? Sorry for the stupid noobie questions. I tried a search, but couldn't find any answers to this specific question. Found lots of other answers though. At least I am learning.
Let me guess... You have only had two beers, and you don't have any idea how that got in there.
Put your seatbelt on, I wanna try something.
73RustBucket is offline   Reply With Quote Quick reply to this message
Old 02-19-2004, 01:41 AM   #2 (permalink)
90TOYPU's Avatar
Member # 16502
If you are worried about the computer and other electronics, be safe and dissconect your battery. If you are welding near parts of the wiring harness make sure you don't melt anything. Other then that watch out for fuel lines. Good luck
[QUOTE=Lance]I can't go to the F*ckin crash. What do you think I have a magic internet? [/QUOTE]
90TOYPU is offline   Reply With Quote Quick reply to this message
Old 02-19-2004, 02:28 AM   #3 (permalink)
Rescue's Avatar
Member # 25600
Yep I agree with 90TOYPU, disconnect the battery everytime you weld on the truck. A lot of guys on this forum says otherwise but I wouldn't listen to them. Hey better be safe than a fried computer!
85 4Runner 35" M/T no lift (fender trim), 5.29, spooled rear, Marlin Crawler dual T-cases, Smurfields, home made can back& pull pal,headers, k&n, Premier power welder, dual batteries, armor, etc.
82 custom short bed (show truck) swapped in a 22RE with W56 transmission riding on 35" BFG's, Sold...
Rescue is offline   Reply With Quote Quick reply to this message
Old 02-19-2004, 03:48 AM   #4 (permalink)
Member # 9382
Send a message via ICQ to BigNorm Send a message via AIM to BigNorm Send a message via Yahoo to BigNorm
Disconnect the negative and you should be good. I've welded on my frame more than once without problems but it doesn't hurt to play it safe.
BigNorm is offline   Reply With Quote Quick reply to this message
Old 02-19-2004, 07:18 AM   #5 (permalink)
stomper4x4's Avatar
Member # 22805
Anny time you weld on your rig you should disconect your battery... I myself have been guilty of forgetting to do so, and as a result i have burned up 2 MSD ignition boxes...
[B][COLOR=Green][QUOTE]
So you want all for yourself alone
And you don't think about the other man
Let me tell you my friend if you gonna live this life
It's not good for you to build strife
Robert Neshta Marley ; Cravin choke puppy[/QUOTE][/COLOR][/B]
stomper4x4 is offline   Reply With Quote Quick reply to this message
Old 02-19-2004, 08:13 AM   #6 (permalink)
Typical White Guy
Member # 9769
As said, disconnect the battery first just to be safe. Also, get a scrap of sheet metal to use as a heat shield when you are welding near fuel lines/wires/etc.
The "A guy I work with says he knows how to weld" has me a bit worried though. I would be checking out some of his welding work before having him do something serious like a roll cage. A guy I hit the trails with had a tow hook welded onto his frame by someone that "says they know how to weld". The first time we hooked a strap up, the hook broke right off and left a huge dent in the truck that was pulling him out.
________
Pro Starcraft 2 Replays
Indyguy is offline   Reply With Quote Quick reply to this message
Old 02-19-2004, 08:43 AM   #7 (permalink)
Member # 5472
Never weld a hook to your vehicle. I have never seen one hold up.
Did you ever notice: When you put the 2 words "The" and "IRS" together it spells "Theirs?"
spoolnaround is offline   Reply With Quote Quick reply to this message
