9 inch - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-20-2004, 01:24 PM   #1 (permalink)
Member # 23593
9 inch
This may or may not a dumb question but I have been trying to find out how to run my 3rd upside down in my 9 inch. whats all involved, thanks in advance.
Nefarious Island Rock Monkeys
Wallace01 is offline   Reply With Quote
Old 02-20-2004, 01:29 PM   #2 (permalink)
Member # 6527
Send a message via AIM to jeepercole Send a message via Yahoo to jeepercole
You can't just run your 3rd member upside down on a 9inch. You can go to http://www.currieenterprises.com/ They make high pinion 3rd members but use the 8.8 inch ring gear.
COLE
jeepercole is offline   Reply With Quote
Old 02-20-2004, 01:38 PM   #3 (permalink)
Member # 23593
you can run the 3rd upside down, with some modifying
Old 02-20-2004, 01:47 PM   #4 (permalink)
Member # 11414
exactly what modifying would one have to do? i have a 9 inch and have thought about the exact same thing. i have also thought about making a custom front housing and using the third out of the rear--only upside down. i wonder if that would work?
Distruction of the soul is vanity...
Rastamon is offline   Reply With Quote
Old 02-20-2004, 01:51 PM   #5 (permalink)
Member # 23593
http://www.pirate4x4.com/forum/showt...hreadid=204951
Maybe one of those guys will chime in and shed some light on the situation.
Old 02-20-2004, 04:36 PM   #6 (permalink)
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
You sure can run your third upside down, you just need to have some way to oil the pinion and ring gear weather it be external oiler or some other way. A lot of the mog9 manufacturers keep that secret, but check wngrog's pinion support with the oil passages.
...But thats not going to be your problem. Your problem will be the fact that you will be driving in reverse.
In vino veritas
70 turbocharged 351w fastback mustang
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
braxton357 is online now   Reply With Quote
Old 02-20-2004, 08:22 PM   #7 (permalink)
chadburgin's Avatar
Member # 18196
why would you be going in reverse. wouldnt it just ride on the coast side? i would like to know more about oiling one upside down?
chadburgin is offline   Reply With Quote
Old 02-20-2004, 08:44 PM   #8 (permalink)
Member # 5021
Do a search on people flipping their axle housing upside down for hi pinion. IT WILL NOT WORK, YOUR TIRES WILL TURN BACKWARDS.
Don't be "THAT GUY" on the trail.
www.voodoowax.com
The Rockslut is offline   Reply With Quote
Old 02-20-2004, 11:18 PM   #9 (permalink)
Member # 18832
Exactly, and nobody makes reverse cut 9" gears. Thats why currie uses an 8.8 gear. And a totally custom centersection to house everything.
marc
91' Cherokee on dual 9's and 38.5's.
marc15663 is offline   Reply With Quote
Old 02-21-2004, 12:11 AM   #10 (permalink)
braxton357's Avatar
Member # 14685
marc
Not to flame, but reverse cut gears DO NOT run in reverse...
In vino veritas
Old 02-21-2004, 12:50 AM   #11 (permalink)
Member # 17313
thats why he said reverse cut, not reverse rotation.
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote
Old 02-21-2004, 01:03 AM   #12 (permalink)
braxton357's Avatar
Member # 14685
Well since noone makes "reverse rotation" gears for anything, and we were talking about reverse rotation HP 9's, More than likely he was referring to reverse cut as running in reverse as most newbs think. I was only clarifying.
In vino veritas
Old 02-21-2004, 04:12 AM   #13 (permalink)
Member # 18910
Send a message via ICQ to Starslope Send a message via AIM to Starslope Send a message via Yahoo to Starslope
With a rear mounted engine, or portals, you can run your axle upside down with normal cut gears. Oiling is a issue though, well covered by wrngogs buildup
[list][*][b][URL=http://www.pirate4x4.com/forum/showthread.php?s=&threadid=135378]Comp. rig:[/URL][/b] Suzuki 410 -85 Olds496cui/TH400/NP205/1350s/D60 front/D60-70 hybrid rear/44x18,5x16,5 [*][b][URL=http://www.pirate4x4.com/forum/showthread.php?s=&threadid=144719]Trail rig:[/URL][/b] Buggy RR215cui/BW55/410/1310s/410 4WS/33x18x15[*][b][u]Daily Driver:[/u][/b] Suzuki 410 -85[/list][URL=http://www.offroad-racing.net][size=4][b]www.offroad-racing.net[/size][/b][/URL]
Starslope is offline   Reply With Quote
Old 02-21-2004, 06:08 AM   #14 (permalink)
moveaside's Avatar
Member # 11983
Personally time and BS don't equal doing this job yourself. Due to the oiling problems of the highpinion 9" its very likely you may have a problem someday. Thats why you want a warranty or the job done right. Just my .02
My crappy build
[url]http://www.pirate4x4.com/forum/showthread.php?t=587635[/url]
moveaside is offline   Reply With Quote
Old 02-21-2004, 08:39 AM   #15 (permalink)
CJeep77's Avatar
Member # 25458
FYI - I am pretty sure they run a t-case oil pump, like a 231 or 241 or something, to lube the gearset in the flipped centersection. I have only seen this done on Mog axles.
CJeep77 is offline   Reply With Quote
Old 02-21-2004, 02:13 PM   #16 (permalink)
Member # 23593
I know about the oiling issues but what else needs to be done?
