setting up gears: how to adjust backlash? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-20-2004, 08:12 PM   #1 (permalink)
Member # 7980
Question setting up gears: how to adjust backlash?
i understand that backlash is the amount of movement between the ring and pinion gears, however my question is how does one adjust backlash? where do you place shims (behind the carrier bearings? [D30])
and will the addition of shims increase or decrease the backlash, bottom line, i don't really know how one would adjust the depth of the carrier, i thought this was just determined by the bearing caps snugging it all down...
thanks
'00 TJ Built, locked, lifted and armored
Sharp is offline   Reply With Quote Quick reply to this message
Old 02-20-2004, 08:16 PM   #2 (permalink)
Member # 15606
I'm not an expert but the pinion should set the depth and the carrier is adjusted side to side.
Put the shims in the same place they were when you took it apart.
'88 YJ, SOA, 8.8 w/Detroit and 4.10's NV3550, and 36's
Neal'88yj is offline   Reply With Quote Quick reply to this message
Old 02-20-2004, 08:29 PM   #3 (permalink)
Member # 7980
ya i know that the pinion gear sets the depth, but everwhere i read...mostly on randy's ring and pinion they keep mentioning that the ring gear must be moved....this is from their site:
"Correct backlash is obtained by
shimming or adjusting the ring gear
away from or closer to the pinion."
this is why i guess i was misled
Old 02-20-2004, 08:53 PM   #4 (permalink)
Rescue's Avatar
Member # 25600
The shims will depend on the axle you have. Toyota 8" for example has shims for the pinion to set the depth of the pinion into the ring. The way to adjust the side to side is by adjusting 2 large nut locks. In your case you might have shims to adjust the side to side.
When I did mine it took me 4 tries to get them perfectly centered with blue methylene, so take your time because it can take a while
85 4Runner 35" M/T no lift (fender trim), 5.29, spooled rear, Marlin Crawler dual T-cases, Smurfields, home made can back& pull pal,headers, k&n, Premier power welder, dual batteries, armor, etc.
82 custom short bed (show truck) swapped in a 22RE with W56 transmission riding on 35" BFG's, Sold...
Rescue is offline   Reply With Quote Quick reply to this message
Old 02-20-2004, 09:04 PM   #5 (permalink)
Member # 15606
Your thinking on the wrong axis.
Closer sideways not front to back.
Old 02-20-2004, 10:06 PM   #6 (permalink)
Member # 13889
Exactly. Pushing the ring towards the pinion decreases the backlash (makes them mesh tighter together) moving the ring away fromt he pinion increases the backlash.
CJ7, 1 tons, 5.7l, hummers, IROK's etc., etc.
scope is offline   Reply With Quote Quick reply to this message
Old 02-20-2004, 11:10 PM   #7 (permalink)
Member # 7980
oh man, what a brain fart, i guess i got to read less at a time and comprehend more!!!
thanks guys
Old 02-21-2004, 04:18 AM   #8 (permalink)
Member # 18276
Not to flame, just FYI...before attempting a gear install, first read, then reread, then read again all of the info, and the instructions that you can on how to do it. It's not difficult once you learn how, and i'm sure it would be much easier if you had someone teach you, but trying to figure out how to do it from reading stuff takes a lot of time to let it sink in so you really understand what's going on and what you're trying to accomplish with each step, and how each step affects every setting.
So if you're asking now how to adjust backlash, i'm guessing you haven't done too much reading on the subject. So again....go read some more, and then read something else, and then maybe do some research....seriously.
-Ron-
Krash80 is offline   Reply With Quote Quick reply to this message
