Jeep - 6 cyl or 8 cyl - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-23-2004, 12:07 PM   #1 (permalink)
Member # 25867
I'm thinkin' about pickin' up a jeep, and I've seen a lot of jeeps with the 6 and 8. Any opinions/pros/cons on these two motors, how they hold up, power, reccomendations, etc
Thanks!
- DW
dwlandis is offline   Reply With Quote
Old 02-23-2004, 12:16 PM   #2 (permalink)
Myanarchy's Avatar
Member # 14059
The Jeep 4.2(258) is a good bullet proof motor with pretty decent power, however if your into power then the AMC v-8 motors are a better choice. The are all pretty decent motors, but if your going offroad you might as well have the v-8.
Jeeper89 is a bitch
Myanarchy is offline   Reply With Quote
Old 02-23-2004, 05:51 PM   #3 (permalink)
Member # 25470
like said, there both good engines, with their good and bad. If you really can't decide v-8 or I6, get the jeep with the better body...
I think you will be happy with either engine though.
jpcj is offline   Reply With Quote
Old 02-23-2004, 05:57 PM   #4 (permalink)
Member # 25470
Old 02-25-2004, 09:39 PM   #5 (permalink)
Beat95YJ's Avatar
Member # 22176
Figure out what Jeep you want (CJ,YJ,TJ or Whatever) and get the biggest available motor. That said I currently have a V8 CJ7, and a 4.0L TJ and they are both great motors.
Beat95YJ is offline   Reply With Quote
Old 02-27-2004, 06:50 AM   #6 (permalink)
Member # 17445
Guess you could look at it this way...if you roll an inline 6 cyl Jeep on the driver's side, you get oil in the cylinders. Passenger side, no oil in the cylinders. Roll a V8, doesn't matter which side, you get oil in some cylinders!
[url="http://mysite.verizon.net/dchurch1/jeep/CJ5"]'73 CJ5[/url].
donjr5 is offline   Reply With Quote
Old 02-27-2004, 07:33 AM   #7 (permalink)
Member # 4374
Send a message via Yahoo to KCjeeper
Originally posted by supernatural
.....5.2, only the ZJ's. I'm pretty sure the WJ's come with the 5.9??
You're wrong...
5.9 (360) was only available on the 98 ZJ. The WJ's came with either the 4.0 or the 4.7.
KCjeeper is offline   Reply With Quote
Old 02-27-2004, 02:30 PM   #8 (permalink)
Member # 26542
401 V8 is the only real Jeep motor.
Hard Rock Holley is offline   Reply With Quote
