AX 15 questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-24-2004, 12:34 AM   #1 (permalink)
BLINGN's Avatar
Member # 26761
AX 15 questions
I was told to use dex 3 atf in my 5 spd. I know they use that in ford t5's hopefully that was the right stuff. Also the drain and fill plug are a 5/16 extension square just fyi. I tried a 1/2 day making a tool, the right tool helps.
make your rig do its job
BLINGN is offline   Reply With Quote
Old 02-24-2004, 05:47 AM   #2 (permalink)
YJ4RoX's Avatar
Member # 1930
My drain and fill are 15/16" hex head on my ax15. Also your suppose to use a GL3 gear oil. Redline MT90 or pensoil syncromesh. GL4-5 eat the brass syncros. I have never heard of running ATF in one.
YJ4RoX is offline   Reply With Quote
Old 02-24-2004, 07:13 AM   #3 (permalink)
sodaboyYJ's Avatar
Member # 17421
Send a message via Yahoo to sodaboyYJ
Only use AFT in the T-case, provided you still have a NP231. The AX-15 uses gear lube.
As like YJ4ROX stated, it's a hex plug to fill on a square drive!
'93 YJ, 5.0/C6/Atlas 4sp/ 38.5 SX's...D60's F&R with ARB's on coils
sodaboyYJ is offline   Reply With Quote
Old 02-24-2004, 07:52 PM   #4 (permalink)
BLINGN's Avatar
Member # 26761
Thanks Guys
you saved my azz I changed the fluid asap wow what a newbie mistake. Oh well,Thanks for not flaming
