D30 vs. D44 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-03-2004, 09:38 AM   #1 (permalink)
Member # 11414
D30 vs. D44
I have searched this site and havent quite found what i am looking for in this subject...
i have a jeep and it has a D30 in it w/4:56. i want to get the upgrade to the stronger U joints and hubs. the reason is simply cost. it would cost me about $600 for the upgrade as compared to a couple/few thousand for a D44 with the same size ujoints.
so what i am wondering is if i get this upgrade for the D30, what is going to be the next weak point? Assuming i get some really good u joints, will my knuckle break? will my axle break? or will it be the ring and pinion?
i will be running 36" tires. and an ARB in the front.
so far with 35's and no locker and two+ years, i have yet to break anything on my front D30 with the small ujoints. .. but then again i have yet to go through little sleuce.
anyway any info on this subject would be greatly appreciated.
Thanks!
Distruction of the soul is vanity...
Rastamon is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 10:08 AM   #2 (permalink)
Stunningly Average
wheelerfreak's Avatar
Member # 4135
It sounds like you are going to have all the work done for you if you are expecting 2k for a front dana44? You can swap a 44 front for much cheaper if you do it yourself, just gotta be willing to get your hands dirty. You have to look at your overall goal for your Jeep to decide if you want to polish a dana 30 or go with a 44. What kind of Jeep is this for? If you are going to swap in locking front hubs and are set on keeping the 5 on 4.5" wheel pattern, don't bother. The hubs with that set up are pretty weak and there really isn't a way to beef them up. if you really want to polish a turd then imho go with alloy inner and outer axles, and the 297 series Ujoint. I'd leave the hubs alone (ASSuming it's a YJ, TJ front dana 30). This would leave the ring and pinion as your weak point, which is not really a good fuse IMHO.
Since you are planning on using 36's and an ARB, I'd go with a 44 and be done with it. Unless you have a dana 60 . You'll spend more time and money trying to band aid your dana 30 along then if you just go with a 44 from the start. Maybe not what you want to hear, but that's my opinion.
The press is a gang of cruel faggots. Journalism is not a profession or a trade. It is a cheap catch-all for fuckoffs and misfits—a false doorway to the backside of life, a filthy piss-ridden little hole nailed off by the building inspector
wheelerfreak is online now   Reply With Quote Quick reply to this message
Old 03-03-2004, 10:22 AM   #3 (permalink)
Member # 7903
1st - this really belongs in the newbie section
2nd- A D30 in what Jeep? I'm guessing you have a CJ based on the u-joint comment, but it would be reallly beneficial to mention that little tidbit.
JohnnyJ is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 10:36 AM   #4 (permalink)
Member # 12229
If it's a Dana 30 in a Cj, I've seen tons of stock hubs break running 35's. I have also seen a handful of shafts bust on 35's. Go with the warn hubs and alloy's if you are going to keep it. You will kill that axle running 36's. I've seen knuckles and everything else break on 36's.
"An intelligent man is sometimes forced to be drunk to spend time with his fools..." Ernest Hemingway
upinit is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 10:47 AM   #5 (permalink)
Member # 62
If its a CJ no way in hell. I've seen CJ ring and pinions blow up with 31's. If its a TJ/YJ upgrade to alloy shafts and upgraded U-joints and you should do allright.
Also there is no reason a dana 44 swap has to cost anywhere near $2000. Also with longfield/CTM/ox joints a dana 44's weak spot is the shafts, even with upgraded shafts, so it is definatly an upgrade above a 30.
Jeff Neves
NE-RokToy is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 10:59 AM   #6 (permalink)
Member # 26995
I am swapping the 30 for a 44 on my CJ right now. After looking at the cost of upgrades for the 30 & the AMC 20, it was MUCH cheaper to swap in 44's from a Wag (actually mine came from a J10). If you keep your eyes open and don't get in a hurry, you can find some good deals where people are ditching set-up 44's in favor of something even beefier. Just my experience, though `
Monkeybutt is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 11:17 AM   #7 (permalink)
Member # 23434
Send a message via AIM to csudman
not to jack the thread but does a stock d30 from a cj have the same size outer shafts as a yj d30 stock. there all 19 spline right
csudman is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 12:29 PM   #8 (permalink)
Member # 24765
I say just go strait to the 44, don't waste your time with the 30. If you do, you'll regret it in the long run.
Real Jeeps are Built, Not Bought
(0IIII0)
White CJ7 is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 12:50 PM   #9 (permalink)
sodaboyYJ's Avatar
Member # 17421
Send a message via Yahoo to sodaboyYJ
The D44 is by far the better way to go, but if you have a hard on for yer D30 you could get an ARB 30/30 kit, trus the sucker, get hardened gears for it and run drive slugs rather than lock outs.
But then again, that D44 would be cheaper after adding all that bling to yer turd 30. A D30 is save-able but at what expence.
Even with a D44 yer still gonna end up needing alloy shafts and CTMs to keep it alive under hard use........I know I did.
The real Q is why not a D60, I know I wish I had a front D60..... actually I do but it's going in the rear
'93 YJ, 5.0/C6/Atlas 4sp/ 38.5 SX's...D60's F&R with ARB's on coils
sodaboyYJ is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 12:54 PM   #10 (permalink)
deadmeat's Avatar
Member # 21498
Since this is already here and not in Newbie, I'd like to ask for one clarification.
A RC D30 is stronger in a front app. gear wise than a standard D44, is this a concern? I mean I hear of U joints and shafts going but rearly gears.
I ask because I am going to upgrade my Xj and I am wondering if I can go with an early Cherokee 44 (LP but high stear possible) or a ford 44 ( RC but must swap parts for high stear.
TIA
deadmeat is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 01:00 PM   #11 (permalink)
Member # 7711
Ford 44 have flat top knuckles on the 3/4 versions.
Sunset the unconstitutional USA Patriot Act!!
Serious discussion makes Bubba sad -BRB
MNBen is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 03:18 PM   #12 (permalink)
Member # 8665
Re: D30 vs. D44
Thanks!
again..IF it's a CJ
weld the spiders....fawk the ARB
throw in some 297 joints and carry spare axles. that's all you need to do.
rockr is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 05:41 PM   #13 (permalink)
Stunningly Average
Member # 4135
IIRC only the XJ's and ZJ's came with RC front dana 30's, YJ's and TJ's have the regular low pinion 30. Let us know what Jeep this is for
Old 03-03-2004, 05:44 PM   #14 (permalink)
Mo
Everyday is Tuesday.
Mo's Avatar
Member # 47
Yup.
Mo is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 06:32 PM   #15 (permalink)
Member # 8665
no that's not true
YJ's are RC
TJ's are low pinion
Old 03-03-2004, 07:53 PM   #16 (permalink)
Member # 24289
Save yourself the hassle and do a 44. Your tires are to much to expect a 30 to handle.
Walt
"I've learned over the years that I have to be careful of the toes I step on today because they could be connected to the ASS I HAVE TO KISS tomorrow."
slapnutz is offline   Reply With Quote Quick reply to this message
Old 03-03-2004, 09:31 PM   #17 (permalink)
deadmeat's Avatar
Member # 21498
I just read my post again and right below this statement i say
"I ask because I am going to upgrade my Xj and I am wondering "
Old 03-04-2004, 04:14 AM   #18 (permalink)
Member # 8665
i would shoot for a high pinion front axle if possible. not only for the stronger gear configuration but an equally valuable ground clearance attribute.
Old 03-04-2004, 04:44 AM   #19 (permalink)
Member # 26995
I may be wrong, but I thought high pinion axles are inherently weaker than low pinions(of the same axle). Something abut the way the gears are cut?
Old 03-04-2004, 06:06 AM   #20 (permalink)
withamc's Avatar
Member # 1757
Not up front.
Usually lost...
Eat your spaghetti
withamc is offline   Reply With Quote Quick reply to this message
Old 03-04-2004, 06:26 AM   #21 (permalink)
Member # 22966
Go with a D44 up front. It'll be much better in the long run. You are asking too much from the D30 with the 36" and an ARB, IMO.
1967 CJ5, 1992 YJ, 2000 XJ, 2006 Commander
mikesimpson is offline   Reply With Quote Quick reply to this message
Old 03-04-2004, 10:44 AM   #22 (permalink)
Stunningly Average
Member # 4135
wash the sand out of your vag The comment was directed to the original poster Rastamon not you. He never mentioned in his post what Jeep he was talking about. Unless of course deadmeat and Rastamon are the same person, cohabitate, or share some illicit man love affair.
Old 03-04-2004, 10:58 AM   #23 (permalink)
Member # 11414
sorry guys, i have a YJ. it is a 93.
the thing is i would like to get a dana 60, but i am not going to be able to afford it until next year *hopefully** so i am thinking that it would be cheaper to upgrade the D30, then next year go all out and put in the D60.
if it is cheaper to do the D44 (which i cant imagine it is...) then i would gladly do that. the problem is money. i get the D44 and i have to do a lot of modification from what i have read here on teh board. i can do the welding of things and even the gear and locker, but from what i have read most D44's dont just fit. they need to be shortened, custom axle shafts, u joints, etc etc.
plus i havent found a supplier or junkyard locally that will part with a front D44 for less than 3-400 bucks. from any vehicle. does anyone know of a place in the sacramento area who would sell me one D44 for cheap? i'd be in the market for sure.
thanks for the help, BTW.
Old 03-04-2004, 11:28 AM   #24 (permalink)
Member # 8665
right on TEAM YJ
ok............here's what i did:
you can get axles for the 95 YJ that will fit right in your tubes/hub bearings assembly. no mods needed. these axles will house the 297 or even the newer 760 joints. just order inner/outers for the 95 YJ. or find some used ones....either way. and pick up spares whenever you can because you will be breaking axles and spinning u-joints if you do any hardcore shit like i do.
being open is why you haven't snapped yet. even with 35's...open is the keyword here.
you already have 4.56 gears so i wouldn't go any lower and run a puny pinion gear. if you have or get the t-case 4:1 gears you will be at 75:1 crawl.
as for the ARB.......fawk that
get a detroit
run on this for a while till you get the full width 60's, BOUGHT, BUILT and INSTALLED. that can take some time.
Old 03-04-2004, 01:39 PM   #25 (permalink)
Member # 22966
If yer then plannning on going to a D60 next year, then stick with the D30 and 35" tires for now, and save your bread for the D60 build up.....
