oil pan drop in a TJ - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-09-2004, 08:01 AM   #1 (permalink)
Member # 24124
Send a message via AIM to BigPerm
Hi.
I'm looking for a decent writeup on dropping the oil pan and changing the oil pump out in a '97 TJ SE.
I went to do it last weekend, but I saw the exhaust being in the way, that I would have to remove the pan and probably destroy the rear main seal, etc... so I said, "not now" I need some good instructions on this job.
Can anyone assist? I did do a search but I didn't find anything I was looking for (searched on "oil pan" and "rear main seal").
Thanks for the help!
Good? Bad? I'm the one with the gun.
BigPerm is offline   Reply With Quote
Old 03-09-2004, 08:24 AM   #2 (permalink)
P&T Jeeps's Avatar
Member # 3916
It's not a big deal at all. the exhaust makes it tight but the pan will slide out. to make it a little easier unbolt where the headers bolt up to the exhaust, it'll give you a bit more slack to work w/.
TJ; ARB'd & ChroMo'd 1-tons; 42" IROK's; Atlas 4.3; 4-linked, 106" WB...
The Build
P&T Jeeps is offline   Reply With Quote
Old 03-09-2004, 12:21 PM   #3 (permalink)
SlowMo's Avatar
Member # 26623
If the exhaust is in the way I'm assuming you've got the 6 cyl. I helped a buddy replace his oil pan a few weeks ago (The drain plug had found it's way into a rock ). We unbolted the exhaust from the manifold and had to drop the T-case skid plate in order to get the pan out. It wasn't too bad except that 3 of the 4 exhaust bolts snapped off when we were torqing them off. I'd suggest having 4 new ones ready to go before you start. You'll also need some new pan gaskets. I suppose you could use Permatex, but it might be kind of a pain.
This Jeep sponsered by the IRS and my tax refund.
SlowMo is offline   Reply With Quote
