How do beadlocks work? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-20-2004, 03:40 PM   #1 (permalink)
GubNi's Avatar
Member # 25927
I understand the concept of keeping the tire from breaking loose at low pressure, but how do they do that? I understand Hummer rims, but they are only available in 8" wide, right? So I'm thinking maybe beadlocks might be good, but I don't understand how they work and all the pics I see are from the front. I'd like to see across the width of the rim. From what I can figure there are just some screw that go through the rim and into the rubber. Why should you buy special rims verses just drill and screw the current rims? I've heard that people like 15" rims because of the safety bead and that 16.5" rims don't have that. Is that true? I'm running 1 ton axles and perfer the 16.5" so I don't have to grind so much. Thanks!
Dana 60 or 14 bolt disk brake kits $315 shipped --> click here
Dana 70 kits $300 --> click here . . Sterling 10.25 kits $390 --> click here
Dana 60 front 3/4 ton kits $350--> click here
GubNi is offline   Reply With Quote
Old 03-20-2004, 05:14 PM   #2 (permalink)
Quit changin my shit
Otto Man's Avatar
Member # 18977
Send a message via AIM to Otto Man
Theres a metal ring on the inside of the rim that you cant see from the outside. The bolt heads visible on the edges are torqued to a spec (usually around 30 ft lbs). The ring clamps the bead of the tire against the rim so you can't lose a bead. Most beadlocks do nothing for the inner bead so I dont see a reason for myself to get beadlocks just for one side.
Originally Posted by Sully
It's a respect issue. Just because you can, doesn't mean you should.
Would you tell your Grandmother to go suck a big black cock, just because you could?
Otto Man is offline   Reply With Quote
Old 03-20-2004, 05:18 PM   #3 (permalink)
Otto Man's Avatar
Member # 18977
after reading your whole post, there are some dirtbike guys who drill into there rim and use screws like you said. My guess is that the screws arent strong enough to hold the bead of a bigger, heavier, bias ply tire.
Old 03-20-2004, 05:31 PM   #4 (permalink)
JeepinDoug's Avatar
Member # 13028
Beadlocks used in our hobby need to be able to take side load without shredding the tire to pieces. Both bikes and drag racers use screws to keep the tire from spinning on the rim.
This pic shows the tire seated onto the inner ring, a shelf behind the tire bead.
This pic show the outter beadring in place sandwiching the bead from both sides before torquing down the ring.
I may lack much in way of integrety but I make up for it with pure denial.
[URL=http://www.pirate4x4.com/forum/showthread.php?t=377480][B][COLOR="Red"]Malvado Grande #1[/COLOR][/B][/URL]
JeepinDoug is offline   Reply With Quote
Old 03-20-2004, 05:53 PM   #5 (permalink)
GubNi's Avatar
Member # 25927
So it doesn't go through the tire, but clamps the tire instead. Why just one side though?
Old 03-20-2004, 06:46 PM   #6 (permalink)
Doublewide engineer
kwrangln's Avatar
Member # 6971
Because the beadlock would leave even less room for your brake caliper on the inside. That and the outside of the tire takes the most flexing during turns and off camber situations.
I'm the "tack tack tack" welding nazi.
http://www.pirate4x4.com/forum/showp...&postcount=218
"I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside
kwrangln is offline   Reply With Quote
Old 03-21-2004, 06:53 AM   #7 (permalink)
Member # 22345
I think that the inner bead is a little larger so it holds the tire a little better...
Balsax is offline   Reply With Quote
