Member # 2650
Location: Home is where the Marine Corps sends you,...right now, it's Kernersville, NC.
Ranger hub and D30 hub interchangeabililty
Here's the deal, a few weeks ago, I shattered my D30 hublock, but, the internals are fine.....I know that the Ranger hub won't work because of the different spline counts, but someone suggested to swap the internals out,....does anybody think this will work as Ranger hubs are a dime a dozen and the replacement hubs for the conversion kit that I have ain't cheap.
Nothing important |
Member # 17313
well, depending on the year of the dana 30, it might be possible since the later 30's used the 760x joint like the HP35.
If you do get it to work, make sure you use the good hubs. The stock ford ones aren't great, and neither are any of the aftermarket ones for the ford. Warn part number 37780 is what you want, they are a direct replacement for the ford ones, but are made for the 35C full floater kit, and are stronger.
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
Member # 10063
The splines ARE the same (27)
That is, unless you put 30 spline stuff on it Edit: Early Rangers ('83-'89) were 23 spline teeny-weenie stuff. But as Jrod already mentioned, the regular stuff is weaker than the Warn Jeep-specific stuff (which also will fit the Explorer/ranger as well).
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s [url]http://www.cardomain.com/ride/702959[/url] |
Member # 2650
I'm running the hub conversion on a TJ, so I have the 297's. The only part of the ford hub that I'll use is the housing itself, I'd take all of the internals out of the ford housing and put the TJ hub conversion internals in the Ford hub,....just using it as a spare.
Here's a pic of the blown hublock, you can see that the internals look fine.
Nothing important |
Member # 2650
Just like 4x4Junkie said, the splines are the same. I got a brand new Ford hub off of ebay for $5 and test fit it yesterday. The hub locks and unlocks and appears to work fine. I'm just going to throw it in the "spare stuff" box and use it if I need it.
Member # 22646
InfantryYJ...how did you blow the hub body ? Do you need any D30 parts, I have some laying around that I'll give ya for free.... 0369's got to look out for each other
" Never underestimate the power of idiots in large groups" |
#7 (permalink) | |
Member # 2650
I did get a replacement from Warn, so right now, I'm good to go, I'll just keep the Ford hub as a spare.
Nothing important |
