4x4 wont disengage - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-21-2004, 03:49 PM   #1 (permalink)
Member # 29645
4x4 wont disengage
The Orange light inside that says PART TIME wont go out, even after I put the shifter back in 2HI. Its drivin all stiff and cant get the light off? It is on a 96 XJ with 80,xxx miles on it.
96XJSport is offline   Reply With Quote
Old 04-21-2004, 03:55 PM   #2 (permalink)
Member # 3974
Send a message via MSN to Isley
Good lord...
Delete this post and go back to JU.
'93 YJ 4Banger
Isley is offline   Reply With Quote
Old 04-21-2004, 03:57 PM   #3 (permalink)
Moderator
apeters89's Avatar
Member # 7647
don't worry, that just means it's only working part-time. It makes it like an all-wheel-drive Grand CHerokee... it was a little known about option on the XJ's w/ Command Trac.
and this guy is a fucking newbie who needs to have a new ass-hole torn into him :blackflipoff2: :blackrolleyes:
Check out our new Team Ape Eater Racing Like us on FaceBook
KF5EQF
Sniper Fab
4x4Oil SBwinVPS Custom Splice C2GFab
apeters89 is offline   Reply With Quote
Old 04-21-2004, 03:59 PM   #4 (permalink)
Member # 29645
Originally Posted by apeters89
dont' worry, that just means it's only working part-time. It makes it like an all-wheel-drive Grand CHerokee... it was a little known about ontion on the XJ's w/ Command Trac.
Yea, but the light wasnt on before I used 4x4. Doesnt drive right either. I had it in 4HI and not 4LO if that matters?
Old 04-21-2004, 04:01 PM   #5 (permalink)
Member # 16217
Send a message via ICQ to JeremyH Send a message via AIM to JeremyH
Are you sure that the linkage isnt binding?
JeremyH is offline   Reply With Quote
Old 04-21-2004, 04:02 PM   #6 (permalink)
Moderator
apeters89's Avatar
Member # 7647
OH, you didn't say that... you need to put it in 4 low, drive in reverse for 10.5 feet. Then shift into 4 hi, drive forward for 10.5 feet. Then shift into 2 hi and drive in reverse for 11 feet. That will remove the orange light.
anyone else wanna play?
KF5EQF
Sniper Fab
Old 04-21-2004, 04:03 PM   #7 (permalink)
Member # 7607
Send a message via AIM to ItsaJeepThing95
How to fix it:
1) Pull your XJ up to the edge of a cliff, top of a parking garage, anywhere with more than a 30 ft vertical drop, preferably on to sharp pointy spikes or cute cuddly rabbits.
2) While seated in the XJ, put t-case lever into Neutrail
3) Any member of the PBB will be MORE than happy to give you a nice little push
ItsaJeepThing95 is offline   Reply With Quote
Old 04-21-2004, 04:07 PM   #8 (permalink)
Member # 29645
Thanks for the help. Ill try. I assume the distance are estimates? Not like Im gonna know if I back up 10.5 feet. Ill try to do close to what you say. I read the owner manual and it said to stop if i put in in Low. I did the 4hi-2hi just like in the manuel.
Old 04-21-2004, 04:11 PM   #9 (permalink)
Moderator
apeters89's Avatar
Member # 7647
yeah, the numbers are estimates, but I wouldn't skimp on the distances. It should fix you up right away though...
gotta do all the work around here myself... :blackrolleyes:
KF5EQF
Sniper Fab
Old 04-21-2004, 04:27 PM   #10 (permalink)
Member # 29645
apeters, I put in Low in the garage then backed up in the street at least 10ft. I put it in drive and was coasting downhill, when I put it in 4HI it grinded BAD, LOUD and the lever vibrated. So I stopped and put jeep in N, the shift to 4HI, then to 2HI. When I backed up it popped and the light went out!!!! Thanks! Seems like a lot of crap to go through to get from 4-2wd itd supposed to be automatic? You got an XJ too?
Old 04-21-2004, 04:29 PM   #11 (permalink)
Moderator
apeters89's Avatar
Member # 7647
damn, he got it working faster than I hoped...
KF5EQF
Sniper Fab
Old 04-21-2004, 04:33 PM   #12 (permalink)
Member # 29645
Maybe all the mud cake dunder it messed it up? I know my brakes are screwed. They are scapin. It must have 30 pounds of mud under it! I went wheelin in a farm field this afternoon. I learnt I need better tires! But it did good!!
Old 04-21-2004, 04:49 PM   #13 (permalink)
Member # 29071
Send a message via AIM to Starboard M
You already dug yourself into a hole with your new jeep thread, but you just seem to want more. You must have had some serious fun in that flat field. Your brakes are messed up with a '98? That must have been some crazy wheelin. Or did you just try what ItsaJeepThing95 ask you to do, and then tried to drive away?
Starboard M is offline   Reply With Quote
Old 04-21-2004, 04:52 PM   #14 (permalink)
Member # 29645
My Jeep is a 96 not 98. It should be good after I power wash it! Im gonna have the carwash bay covered in mud! haaaahaa! Not having that junk in MY driveway!
Old 04-21-2004, 04:52 PM   #15 (permalink)
antipodalboy's Avatar
Member # 24336
so you went coasting down a hill and shifted your tcase while you were in gear.....dude, start searching and get your stupid newbie ass to the appropriately named forum.
antipodalboy is offline   Reply With Quote
Old 04-21-2004, 04:55 PM   #16 (permalink)
Member # 29645
yea, felt like a dumass but did what apeters said. I just wanted that stupid light out and my 4x4 to disengage. Its all good now. Hope that ginding dint bust anything
Old 04-21-2004, 05:07 PM   #17 (permalink)
Member # 23396
I'm having a hard time discerning if he's being serious or not
[size=1]Someone told me once that there's a right and wrong, and that punishment would come to those who dare to cross the line. But it must not be true for jerk-offs like you. Maybe it's just bullshit and I should play GOD, and shoot you myself.[/size]
Outshined is offline   Reply With Quote
Old 04-21-2004, 05:28 PM   #18 (permalink)
ZAG
ZAG's Avatar
Member # 14113
damn he is stupid
ZAG is offline   Reply With Quote
Old 04-21-2004, 06:36 PM   #19 (permalink)
Member # 4321
Send a message via ICQ to DEnd Send a message via AIM to DEnd Send a message via MSN to DEnd Send a message via Yahoo to DEnd
I really hope you had permission to be on that farm feild, If you didn't you just made everyone that owns a 4x4 look like a jackass.
Lame Sig Line
DEnd is offline   Reply With Quote
Old 04-21-2004, 06:49 PM   #20 (permalink)
Member # 29645
Well, it was just dirt so not like its a big deal. My tires are only 235/75/15s so not like I left huge ruts!
Old 04-21-2004, 06:58 PM   #21 (permalink)
Member # 13966
You are quicky becoming the poster child for birth control, free abortion and Toyota ownership. All in one moronic package.
Joe
[FONT=Comic Sans MS]See, I told you it would break.[/FONT]
Rocktoyo is offline   Reply With Quote
Old 04-21-2004, 07:03 PM   #22 (permalink)
Member # 29645
So why is this place act like a soap opara? I posted in the JEEP section of the board about my JEEP and then it gets moved here...well it got fixed so its cool, but al these people in here got different 4x4s so I wont get Jeep info. I wont ever own JAP 4x4s anyways. Theres only 1...JEEP!
Old 04-21-2004, 07:06 PM   #23 (permalink)
Juice's Avatar
Member # 24306
Send a message via AIM to Juice
Originally Posted by ItsaJeepThing95
How to fix it:
hahahahahaha
82 K5, 6.5L diesel, 35's, welded rear.. work in progress
Juice is offline   Reply With Quote
Old 04-21-2004, 08:39 PM   #24 (permalink)
Member # 18806
Send a message via ICQ to KaceCoyote Send a message via AIM to KaceCoyote
I've got the same truck dude. First step. Leave. I'm not gonna be rude, but this isnt a place for newbs. This is a seriously hardcore rockcrawling board. If you seriously wanna learn something, shut up and utilize the search function. Post only when you need specific clarification, and assume that you will be shot on sight if you step outside of the newbie forum.
"All that is complicated is worthless, all that is simple is useful." -Kalashnikov, creator of the AK-47/74/101/102/103/Saiga ect ect
KaceCoyote is offline   Reply With Quote
Old 04-21-2004, 10:01 PM   #25 (permalink)
Member # 25322
not completely true...
----In 5/16" chain we trust----
I can operate any vehicle beyond it's limits
GONRACIN is offline   Reply With Quote
