Newbie Disco Brake Question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-22-2004, 09:46 AM   #1 (permalink)
Member # 11737
Send a message via AIM to Jeeptoy91
I am a complete Newbie when it comes to working on our Disco (spend my time working on the Jeeps). Where is the best (read least expensive) place to get the disk brake pads? I need to do a brake job on the 98 disco.
Just a YJ with some expensive parts
Jeeptoy91 is offline   Reply With Quote
Old 04-22-2004, 09:58 AM   #2 (permalink)
Member # 21218
MMM
Cheapo pads they wear your rotors out before themselves.
Fit some decent pads from Ferodo/brembo
easy to change with a few tools.
Tony
Defender 90-Modified
tony cordell is offline   Reply With Quote
Old 04-22-2004, 10:05 AM   #3 (permalink)
Member # 9817
many times you can scare up a set of Mintex pads off eBay - fwiw. failing that, i generally use discountrovers.com, british pacific, or NAPA i am running some rotors I obtained from NAPA with mintex pads and they've been great together.
cheers,
isaac
'97 Discovery
SeaRover is offline   Reply With Quote
Old 04-22-2004, 10:49 AM   #4 (permalink)
Member # 11737
Turning rotors
I have my Jeep rotors turned at Napa. Are most places in the USA set up to turn Rover rotors?
Old 04-22-2004, 12:29 PM   #5 (permalink)
Member # 13149
I'm pretty sure you will find that the shop manual says to replace rotors and not to turn them.
Mike
LRover is offline   Reply With Quote
Old 04-22-2004, 01:33 PM   #6 (permalink)
Member # 11737
replace?
Can they be turned? What's the problem with turning them?
