Ford 8.8 with abs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-22-2004, 10:01 PM   #1 (permalink)
Member # 27305
Ford 8.8 with abs
I want to swap in a a ford 8.8 out of an explorer. My jeep has abs and I have heard that the 8.8's have abs sensors. Is it possible to hook up the abs sensor to be able to maintain my abs?
agentorange1592 is offline   Reply With Quote
Old 04-22-2004, 11:04 PM   #2 (permalink)
Member # 8477
ford 8.8's use a sensor atr the ring gear jeep uses one at each wheel.
If you were dead set on doing it probably the easiest way would be to take you existing jeep tome rings and machine them to press onto the 8.8 shafts. then drill a hole in the caliper bracket and mount your factory sensors within spec.
most people say that it stops better without abs anyways. I thought about setting an old D44 up with abs just because a bunch people told me it couldn't be done. then I found some other stuff to do.
where in Wdnvl?
CHEROKEEKID is offline   Reply With Quote
Old 04-22-2004, 11:37 PM   #3 (permalink)
Member # 26210
Send a message via AIM to GoingOffRoading
DON"T DO IT!!!!!!!!!!! ABS is junk in my opinion. I have "ABS" its called 35"s on stock brakes. Actually the abs system failed in my ZJ and that caused my first and only car accident. Wheeling with ABS on, I'd hit a bump and the brakes would go to the floor but I would still be rollin.... I've been alot happier without the ABS
GoingOffRoading is offline   Reply With Quote
Old 04-23-2004, 12:13 AM   #4 (permalink)
Norcaljr's Avatar
Member # 10319
Send a message via AIM to Norcaljr
x2
Norcaljr is offline   Reply With Quote
Old 04-23-2004, 12:50 AM   #5 (permalink)
Member # 26210
I will say this... makes for some scary high speed braking... but then I guess that could be expected~ ZJ 8" of lift 35"s on jeep width axles.
Project D-Day...
[url]http://www.fototime.com/inv/9D156C7468B8053[/url]
I have a Lincoln 135t for sale... PM me for details
Old 04-23-2004, 06:55 AM   #6 (permalink)
Member # 7607
Send a message via AIM to ItsaJeepThing95
I know a guy who converted his 8.8 to ZJ style ABS, but it's so not worth it. If you have a rig where you're doing axle swap, I doubt ABS should be much of a concern for you anyways.
ItsaJeepThing95 is offline   Reply With Quote
Old 04-23-2004, 08:27 AM   #7 (permalink)
Steve N's Avatar
Member # 112
ABS is the devil.
[COLOR=yellow]it's all about show & shine[/COLOR]
[COLOR=Lime] Stiffy®? why screw around with anything less? [/COLOR]
Charter member PBB mod divorce club for men.
Steve N is offline   Reply With Quote
Old 04-23-2004, 08:35 AM   #8 (permalink)
Member # 15192
Send a message via Yahoo to TheBadXJ
If you're dead set on using abs, you can get an 8.8 out of a lincoln Mark 7. It has disc brakes with the abs tone rings at each wheel. HTH.
Jeep thing my ass, buy some lockers
Famous Last Words
"Its not that deep"
"Just give it a little gas"
"Sure, I can kinda weld"
TheBadXJ is offline   Reply With Quote
Old 04-23-2004, 04:57 PM   #9 (permalink)
Member # 7607
Isn't that a 28 spline as opposed to a 31?
Old 04-23-2004, 10:11 PM   #10 (permalink)
Member # 17313
yes
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote
