Cuting the top off K5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-26-2004, 07:11 PM   #1 (permalink)
Member # 28187
Has enybody ever cut the top off there Blazer?I have cut doors to make replacements for 73-75 blazers.I want to cut the top off my 76k5.has enybody out there ever done this?I was thinking of trying to make it so that a soft top for a 73-75 would work.i was also wondering if I need a full cage to keep the body from doing something wierd.Let me know if enyone did this. Thanks JB
BlaznJon is offline   Reply With Quote
Old 04-26-2004, 08:18 PM   #2 (permalink)
Member # 13967
It's been done, you'd probibly want a roll bar over your head through, just for safety.
The bodies are ify, they have the strength in them to maintain there resiliance, and not warp. But you'll have more twist, and eventually not be able to shut your doors.
My suggestion, would be, cut the roof off, and replace it with a rollbar that's attached to the frame. Or put a 2" body lift or so, and incorporate the cage into that, you could run pipe under the body, as your lift, and hoop it over head. That way you could run poly bushings to dampen the noise it would produce..
Good luck..
If it's Big, Bad, and Ugly.. It was probibly my ex...
78Jimmy is offline   Reply With Quote
Old 04-26-2004, 09:23 PM   #3 (permalink)
Member # 29210
Send a message via AIM to Davethorik
69-75 full convertible blazers had "rocker boxes" that were used to stiffen the body, since there was no connecting roof to do that job. i know someone is going to make repop rocker boxes for first gen blazers, as they seem to be a common rust area...so perhaps they already make repops for 2nd gens, or maybe you could get a used set from a rust free area and swap them into yours. or make a set.
you might not even have to do this if you make your 'cage correctly.
:laughing:
Davethorik is offline   Reply With Quote
Old 04-27-2004, 08:07 AM   #4 (permalink)
cegusman's Avatar
Member # 5738
Do a search on www.coloradok5.com it has been covered befor.
1982 Chevy K5 Blazer 6.2 Diesel\SM465\NP205
Front: Dana 60 4.88 Detroit 1410. 52" Spring swap and a 4 degree tapered Zero Rate
Rear: 14 Bolt 4.88 Detroit 1410. Disk Brakes. Stock 56" springs DIY4x Shackle flip and a 1" Zero Rate
38.5x14.50-15 SX's - 15x9 bead locked wheels
[URL="http://www.pirate4x4.com/forum/showthread.php?p=6018956&posted=1#post6018956"]My Build Tread[/URL]
cegusman is offline   Reply With Quote
Old 04-27-2004, 01:07 PM   #5 (permalink)
ChevyGal's Avatar
Member # 4033
PM Muddin. She has hers done.... bet she would be able to at least give some advice, maybe even has pics.
Needs more cowbell!
ChevyGal is offline   Reply With Quote
Old 04-27-2004, 05:02 PM   #6 (permalink)
Member # 28187
Cutting the top off
Thanks everybody.I think I found a 74 for agood price.I`ll keep the 76 for mud the way it is,make the 74 my Summer ride!Thanks again! JB
Old 04-27-2004, 05:05 PM   #7 (permalink)
Tactical Turtleneck
Urban Wheeler's Avatar
Member # 26369
Send a message via Yahoo to Urban Wheeler
Don't they just unbolt, or was that earlier models?
Originally Posted by usmcdoc14
sell. the correct word is "sell" you mouthbreathing fuck.
Type like you have a clue.
Urban Wheeler is offline   Reply With Quote
Old 04-27-2004, 05:15 PM   #8 (permalink)
tanman2003's Avatar
Member # 19325
he is talking about taking off the part of the roof that covers the front seats. the later models only had a back half top.
tanman2003 is offline   Reply With Quote
