cv strength vs. standard u-joint
im getting new drievshafts for my scout II soon and i need to find the angles that my driveshafts will be at. i can either just get the CV joints (more money,i know) or the standard u joints. i bet i will be getting a cv for the front but if i can get the standard u-joint setup would that be better than the cv strength wise? anythin else that i should know about cv's such as maintenance? i did do a search but i didnt get what i was looking for.. thanks
charlie
71 scout II online crabbing games are where its at |
Member # 16436
CVs suck. They really suck to rebuild in the woods. Avoid 'em if you can. Don't bother buying 'em. It really sucks to rebuild one you just paid for. Find the closest one in the boneyard, and stock up.
Member # 16436
Personally, I think credit card wheelers who buy every high tech part out of a catalog because some magazine/web site/know-it-all tells 'em they have to have it are stupid. Dodge Durango CV shafts are a direct bolt in to my truck. I get 'em free, because they often get warranteed for a squeak. Dealer techs just swap shafts (they don't bother rebuilding the Cardan joint. Hmm.) So yeah, once or twice a year gotta swap/rebuild mine. It sucks if it's on the trail, and pissy know-it-all trust fund 'wheelers think it's stupid when they read about it sitting at their computers. I'm setting up my next truck to run u-joints to avoid this. I recommend the same.
Member # 20394
Sometimes u-joints are not an option due to excessive angle from lift or shaft lenth. Then a cv is the only option and a good one. They can be just as strong as u-joints but they do cost more, but, nice things cost money.
BUCK Wild Racing Team 911 Thank you all for your support Widia Cutting Tools www.widia.com PSC www.pscmotorsports.com/ Ruffstuff Specialties www.ruffstuffspecialties.com Artec Industries www.artecindustries.com Tom Woods Drive Shafts www.4xshaft.com www.facebook.com/buckwildracing |
#6 (permalink) | ||
#7 (permalink) | |
2012 Tahoe 24' Fish-N-Fun Tritoon, w/115hp Merc Tow Rig: The Battlestar Galactica |
I GAF!
Member # 29802
I'm just a po-ass cracker from Alabama but I can tell you this. I will be buying high angle driveline one ton c/vs cuz Im going SOA and using 4" lift springs on my CJ and I want to lessen the chances of a breakage on the trail.
Spend more $$ up front and have more fun on the trail (less breakage) As will all things, the strength is gonna depend on your driving style. If your wild, nothings gonna hold up. If you have a resonable foot, you stuff should hold up fine. I'm all for the c/v's.........pay more now, less headaches later....
FBook "There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die." |
Member # 21548
put it this way
ujoint are fine for close to stock angles, and equal pinion/t-case output angles if you go high, or cut and turn the front axle, you will NEED a cv joint just to run over 15 mph without insane vibration. i found a cv shaft for 20 bucks from a guy who has CJ's, just get a local driveshaft shop to find you the right adapter for the t-case output and your ready to go.
What fun is a sweet truck if you don't abuse the piss out of it? |
so i imagine i should get the cv's even if i dont necesarily need one for daily driving. im thinkin more for when im flexing or have some drop in the rear axle it would be helpful. im pretty sure this axle was cut and turned but i still need the cvs for the front too probably. thanks for the help
#11 (permalink) | |
Member # 16502
I am not an expert. A single U-joint of similar size to what's used in a CV is generally stronger. But as mentioned before angles usually dictate what you have to run. If you are concerned about strength try to step up to a bigger size CV. Yes CVs take more maintenance. You have two U-joint versus one and you have the center "ball" that has to be dealt with also. What it comes down to is figure out your angles. If you can run a single u-joint. Go for it. If not run a CV that is the appropriate size/strength according to how your rig is built. As always Jesse at High Angle is very helpfull in figuring out good setups. Good luck.
