Member # 29033
ford 9 in ?
are hp and lp 3rd members interchangeable? can you remove a lp 3rd member from a housing and replace it with a hp 3rd member? if the housings are different for a lp and hp , how do you tell the difference if your buying just a housing with the axles and brakes?
Member # 17313
you do know the HP 9" is just a custom case from currie, to allow to run HP 8.8 gears, right? there is no factory HP 9"
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
#5 (permalink) | |
Member # 22966
1967 CJ5, 1992 YJ, 2000 XJ, 2006 Commander |
Member # 29033
i wasnt sure if you had to have the currie housing in order to use the hp 3rd member. im looking at buying a housing with 31 spline shafts, discs, and no 3rd. he says its supposed to be a currie housing.
