Difficulty Rating to replace Lights\Turn Signal Assembly - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-02-2004, 09:57 AM   #1 (permalink)
Member # 30228
So I have 2 questions, however they may very well be the same problem.
Specs:
1996 Land Rover Disco
Pretty much all stock
Background:
6 Months ago brights stopped working, when lights are switched (regular-to-bright) the lights completely go out (possibly short?), kind of intermitent (works about 5% of the time).
1 month ago rotating switch (to turn lights on) started feeling 'crunchy' (like broken plastic).
1 week ago rotating switch stopped functioning correctly. Running and dash lights turn on but go out completely if the switch is turned to turn on the main headlights.
1st Question: has anyone had a similar problem with the Brights not working but regular headlights are fine (my guess is that it's, and always has been, the assembly)
2nd Question: How hard is it to replace the Turn Signal\Lights assembly, I found it new for $200; however I do not have a shop or technical manual.
The manual is definetly on my list of must haves, there's just never enough $$ though.
basixs is offline   Reply With Quote
Old 05-03-2004, 05:10 AM   #2 (permalink)
Member # 11256
it's too hard don't do it. take it to a dealer they know everything
ben
m016324 is offline   Reply With Quote
Old 05-03-2004, 05:50 AM   #3 (permalink)
Member # 17316
I don't see how you can afford to own a Disco but not afford a workshop manual.
1996!!! Usually by this age the Lucas electrics have failed completely. Count youself lucky and buy night vision goggles before the rest of the lighting system fails. Failure of the complete lighting system can only be repaired by replacing the vehicle, so all of us CB's on this board just use night vision goggles to drive at night.
If you are crazy enough to attempt the repair youself don't forget to replace the blinker fluid.
Cheers,
Ben.
ISUZUROVER is offline   Reply With Quote
Old 05-03-2004, 06:54 AM   #4 (permalink)
Member # 12313
Send a message via AIM to WBDISCO
I second the blinker fluid, it took me 3 days to finally get my lights hooked up, and they still didn't work. I had to take them all out again and add 2 quarts each of 90W blinker fluid and BAM they worked like a charm.
It don't have to look good, we ain't building a Rolex.
1996 Disco on 35s
1982 Yota Pickup on 35s (I did a bad thing)
WBDISCO is offline   Reply With Quote
Old 05-04-2004, 12:47 PM   #5 (permalink)
Member # 30238
Send a message via Yahoo to discochick
Wink and then there was light....
don't be too hard on him...... without a manual, he couldn't know about blinker fluid........ at any rate, i agree with the first post.... take it to a mech., but buy the part yourself, just have them install it....
discochick is offline   Reply With Quote
Old 05-04-2004, 01:08 PM   #6 (permalink)
Disco's Avatar
Member # 96
Send a message via AIM to Disco Send a message via Yahoo to Disco
Hey, that's false advertising, you ain't my chick.
R.I.P. Rachel Anne Gray - I miss you and will always love you!!
R.I.P. Dennis. We miss you!!!
California Creepers KI6TMC
Disco is offline   Reply With Quote
Old 05-04-2004, 01:22 PM   #7 (permalink)
Member # 30238
Thumbs down
........and i would want to be your chick why????????? gimme a reason here, because i can't think of any....
Old 05-04-2004, 01:54 PM   #8 (permalink)
Disco's Avatar
Member # 96
WOW, a little testy huh? I was just messin with ya. Lighten up a little.
Old 05-04-2004, 03:59 PM   #9 (permalink)
Geesh's Avatar
Member # 4787
Send a message via AIM to Geesh
Originally Posted by Lance
Newbie General 4x4 Discussion rules
. . . . Flaming newbies will not be tolerated in this forum. If you don't want to help people with their questions, don't visit this forum.
D'oh
I'd suggest a phone call to the Land Rover dealer/service desk. They will prolly tell you bring it in, but who knows, you might catch someone in a good mood. But I bet it is only a couple of screws and some tabs; prolly quite easy. If you don't want to get a shop manual, peruse the local autoparts store and 'library' it there. But be cool and buy something anyway, even if it's small. Also, another source for shop manuals is in your local library
Good luck, and don't mind the bashing
wrapped in pleather
Geesh is offline   Reply With Quote
Old 05-04-2004, 05:02 PM   #10 (permalink)
Member # 28152
try buying a new "flasher". they're like $2 at most mechanic shops, i had a problem were my turn signals didn't work and my high-wipers quit working. The new flasher fixed both problems. I don't know if that will fix the high-headlights but its worth a shot at to see if that will fix it, instead of paying $200 for a whole new assembly.
bpjeep is offline   Reply With Quote
