Whats the biggest tire you run on stock f-150 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-31-2004, 12:00 AM   #1 (permalink)
86cherokeexj's Avatar
Member # 22618
I've got a 99 F-150 4x4 thats completely stock, its starting to need new tires and I got a tip that stock H2 BFG AT's would fit it. Since its pretty easy here to get a set of "take offs" from the dealers here I was just wondering if any body on here was running them or maybe an equivalent size. The stock H2's are 315/70R17. I've already measured them and they will fit definitely as long as I stay on flat ground, I was just wondering if anybody here could tell me how much, if at all they rub. Thanks in advance.
"Who cares, that shit will buff out"
86cherokeexj is offline   Reply With Quote
Old 05-31-2004, 12:03 AM   #2 (permalink)
Andy351's Avatar
Member # 22290
Send a message via AIM to Andy351
better stick to 30s just to be safe
www.PolyPerformance.com
WE GOT WHAT YOU NEED
When people in the Taliban are riding around in better trucks than you, you might have a problem.
Andy351 is offline   Reply With Quote
Old 05-31-2004, 08:15 AM   #3 (permalink)
Member # 18056
Send a message via AIM to fiend
32x11.50, maybe 33's with some fender trimming.
fiend is offline   Reply With Quote
Old 05-31-2004, 09:19 AM   #4 (permalink)
Member # 31425
Send a message via AIM to Ramboss429 Send a message via MSN to Ramboss429
I am running 285-75x16 Cooper STTs on my '99 right now without any problems. I am sure you would have to do some fender trimming (Front plastic piece on front bumper) to clear 315s.
Ramboss429 is offline   Reply With Quote
Old 05-31-2004, 12:01 PM   #5 (permalink)
Bluebeast393cid's Avatar
Member # 29382
hummers r 35s and i dont think that u could clear that with no lift...IMO
Bluebeast393cid is offline   Reply With Quote
Old 05-31-2004, 12:17 PM   #6 (permalink)
Member # 31425
I think you could get away with 35s and a 3" body lift. But if you want the fenders filled up a lil, and better off road capabilty maybe throw on some 33s, these may need just minor trimming of the plastic on the front fender. My 285s don't rub at all, and I've had the pickup up on rocks, thru lots of mud and snow.
Old 05-31-2004, 02:42 PM   #7 (permalink)
Member # 23145
i could swear that the h2's come on 33's im not sure on the numbers but i remember reading that in Petersons or something similar...maybe im mistaken.
'94 XJ ,5150s,trussed,aussied D30/narrowed,spooled 33 splined,moser shafted 9",36" TSLs
Foolsize is offline   Reply With Quote
Old 05-31-2004, 06:08 PM   #8 (permalink)
Member # 31425
H2s definately come with 35s.
If you wanted a lil more clearance in the front of your '99 you could always crank the torsion bars, not that I am reccomending it.
Old 05-31-2004, 06:14 PM   #9 (permalink)
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
315/70R17 = 31.5 CM wide, 22.05CM sidewall height(70 is the sidewall height in percentage of the width), Radial tire, 17" rim, so, 12.4" wide, 8.68" tall sidewall. 8.68x2+17= 34.36" height.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making
96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... [URL="http://www.pirate4x4.com/forum/showthread.php?t=853402&highlight="]Build[/URL]
82F100SWB is online now   Reply With Quote
Old 05-31-2004, 07:51 PM   #10 (permalink)
Member # 31411
31 x 10.5 Is the tire shops opinion on the biggest tire u can run on a stock F150 , I had a 86 and the 31 didnt rub on the turning but they got really damn close
74F250Custom is offline   Reply With Quote
Old 05-31-2004, 08:17 PM   #11 (permalink)
Member # 17313
The tire shop is full of shit.
The factory 265/70-17 converts to a 31.6x10.4, and if your 86' barely cleared 31's, the springs were shot. most fit 33x12.50's just fine stock.
As for the new trucks, I tried to put my 34x9.50 swampers under my dads 00' F-150, the tires physicaly would have fit fine.(but the rims were wrong, obviously)
As for the hummer tires, I bet it would be tight, they are basicly a 35x12.50. Crank the torsion bars and they might fit.
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote
Old 05-31-2004, 10:01 PM   #12 (permalink)
Member # 26338
if you crank the torsion bars they will fit and with no rub on the street i know of two guys that did this on a 2000 and a 2002 supercrew and 315's fit.
78 bronco 460/c-6/sterling 10.25/ 7 in of lift on 38's, with lincoln locker and hydro assist.
95 bronco daily driver
76 wagoneer
47 jeep/willys truck
stx4wheeler460 is offline   Reply With Quote
Old 05-31-2004, 11:25 PM   #13 (permalink)
Member # 16333
Send a message via AIM to RedNeckRea Send a message via MSN to RedNeckRea
since no one else is saying it, I will....
WHY THE FAWK DO YOU WANT A TIRE THAT BIG IF YOU CAN ONLY STAY ON FLAT GROUND? the point of bigger tires and lifts and lockers and what not are for better performance OFF ROAD. I dunno about you but I don;t know many places off road that are flat.
in other words, leave your mall crawler alone and build something you are actually gonna play with. either that or build something that will stay on "flat ground"...a ricer
~Chris, retired US Navy Sailor
RedNeckRea is offline   Reply With Quote
Old 06-01-2004, 03:21 PM   #14 (permalink)
Member # 22618
since no one else is saying it, I will....WHY THE FAWK DO YOU WANT A TIRE THAT BIG IF YOU CAN ONLY STAY ON FLAT GROUND? the point of bigger tires and lifts and lockers and what not are for better performance OFF ROAD. I dunno about you but I don;t know many places off road that are flat.
duh no shit i never said my truck was an offroad vehicle it is my mall cruiser its just that i have a buddy at the dealership here who can get me a really good deal on the h2 take offs so that way i can save some money on new tires for my mall cruiser and put some more money in my toys all i did was ask for some advice from peolpe who might actually know what they are talking about
