Member # 29842
Need LA adjustment advice
Taking the recommendation of others to help me out with the binding issue of the Currie drag link, it was suggested to shorten the lowers more than what RE says to set them at.
I went from 37 15/16ths to 37 3/8ths. • Now I have less than ¼” of threaded rod engagement on the upper radius arm to the flex joint on the lower arm mount • Had previously 5.5 neg caster and what looked like the same pinion angle as was with the 4.5 short arm kit before the LA upgrade. Now have zero. My plan is to rotate the D30 pinion down, which will rotate upper axle arm mount back. Which will then allow me to screw in further to the flex joint on the mount on the lower arm- Restoring better cast and pinion angle. I think there should be more than ¼ “of thread into the joint also. I’m thinking of jacking up the front frame of the jeep high enough to then jack the axle up some then, remove the tires, lower jack a little then rotate pinion down along with the knuckles, tubes, etc. Whats the best way to do this part? If there’s a better way let me know Then: • Start over again and pull in both lowers (same length right?) • Get decent caster/pinion angle • Tire spacing front to rear in the wheel well dead on • Then adjust uppers to fit once everything is OK elsewhere • Then center axle w/tracbar. Also (this is my 3rd lift install on the jeep) I’ve always adjusted the left side arms, uppers and lowers, then gone on to the right side-thinking you get one side set to hold, then adjust the other. Yes, no? Been working solo all day and just looking for some feedback, ideas, suggestions, flow chart, etc on the best way to accomplish this. I think I’ve been looking under there so long bolting, measuring and unbolting- I got tunnel vision now and something simple is escaping me to do this in a simpler way. Thanks a lot, Tom |
Member # 3607
Sugget posting some more info....
While never messed with Jeeps, have done pelnty of long travel stuff. Few suggestions. Set you lowers, making sure you wheel base measurement is the same L & R Set the uppers so that you get the caster angle correct -4.5 to -5.5 sounds good. Adjust the track bar. 1/4" engagement is not enought 1/4" to 1/2" off on long travel stuff would not alarm me, especiall on a Jeep. OEM build is occasionally off by 1/4. I would be more concerned that every thing fits, cycles cleanly, has 0 bind than achieving exact measurements per the instructions. Take a break, then have at it...
PacNORE.com and BlueCoyoteRacing.com * UTV 1997 |
Member # 28024
to adjust the upper arms: take one upper off, put a bottle jack under the lower trackbar mount and use it to rotate the axle until there is no resistance on a bolt of the other upper arm. then pull the bolt off, adjust the jack until you have the caster right, and put the arms back on.
