Tilt column - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-14-2004, 02:57 PM   #1 (permalink)
Grendel's Avatar
Member # 10448
Send a message via Yahoo to Grendel
Tilt column
How tough is it to rebuild a Chevy tilt column?
I was an idiot and fawked the tilt joint in the column, so it has plenty of play in it now.
Grendel is offline   Reply With Quote
Old 06-14-2004, 03:04 PM   #2 (permalink)
Geesh's Avatar
Member # 4787
Send a message via AIM to Geesh
There are three screws that retain the tilt part of the column. I had the same problem and researched the topic here on PBB. In that thread there was a link to a nice DIY page on the GM column someone had authored. If I knew the search strings, I would point you to the threads, but I cannot remember them now, sorry. I know it exists, so I'd suggest plugging away at it. There is also a tool that is available at Checker, Pep Boys, etc, that compresses the spring allowing for assembly.
Good luck
wrapped in pleather
Geesh is offline   Reply With Quote
Old 06-14-2004, 03:10 PM   #3 (permalink)
thomjpster's Avatar
Member # 24471
Send a message via MSN to thomjpster
I made a spring compressor out of an old sway bar clamp. you need to puch a plate down against the spring to install a c clip.
There a PITA, but doable.
I was lucky and grabed 2 columns, 1 for reference, and one to fix the wheel lock.
My hot rod
[url]http://www.pirate4x4.com/forum/showthread.php?t=720301[/url]
thomjpster is offline   Reply With Quote
Old 06-14-2004, 03:53 PM   #4 (permalink)
Grendel's Avatar
Member # 10448
You mean this:
http://www.chevyasylum.com/column/tiltcol.html
