Weight Differance: Bias vs. Radial - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-18-2004, 06:54 AM   #1 (permalink)
Member # 32093
Just wondering which would be heavier a Bias tire or a Radial tire? I am just referencing the tire itself not the wheel and tire. So for example take the IROK 36x13.5x15 Bias and the 36x13.5x15 Radial straight off the manufactoring lines... Which weighs more?
I was thinking bias would be heavier however, late yetersday afternoon I spoke with Interco and they gave me the following specs:
IROK Radials:
36x13.5x15 81lb
37x12.5x15 77lb
IROK Bias
36x13.5x15 66lb
TSL Super Swamper Bias
36x12x15 65lb
I thought for sure Bias ply tires would be heavier..... The only reason I am posting is because when I talked to them it sounded like I was talking to someone who was filling in for there tech question person. Has anybody else heard the same?
Black-Widow is offline   Reply With Quote
Old 06-18-2004, 03:37 PM   #2 (permalink)
b454rat's Avatar
Member # 16536
I have a set of old school Gumbo mudders, 40x17x16.5 that of course are bias. I just got a set of 37x12.5x16.5 G/Y MT radials, and the MTs are heavier than the mudders.
b454rat is offline   Reply With Quote
Old 06-19-2004, 04:37 PM   #3 (permalink)
#1maynard's Avatar
Member # 18828
WOW! how much tread was left on those 40's???
#1maynard is offline   Reply With Quote
Old 06-19-2004, 08:51 PM   #4 (permalink)
Member # 30230
Who cares how much they weigh, you'er gonna break anyway!
deadandcompany is offline   Reply With Quote
Old 06-20-2004, 10:16 AM   #5 (permalink)
wheatfield's Avatar
Member # 8990
Every little bit helps, incase you have been under a rock lately, less weight is a good thing. He is asking a newb question in the newb fourm so give a actual answer or shut up.
Scott
wheatfield is offline   Reply With Quote
Old 06-20-2004, 05:34 PM   #6 (permalink)
Member # 15049
I just went from 38.5x15.50x16.5 TSL SX to the 37x12.5x17 MTR's, the MTR's are alot freakin' heavier. I mean ALOT heavier!
1986 K30
sw99 is offline   Reply With Quote
Old 06-20-2004, 11:17 PM   #7 (permalink)
Pedal Junkie
Mutt's Avatar
Member # 8649
Steel belted radial
Nylon (rope) Bias ply
Which one's heavier
-Steve
43" SX, h1's, ori's, ord magnum/np205, D60/D70, lq4, th400, bentfab chassis ....some assembly required.
Mutt is offline   Reply With Quote
Old 06-21-2004, 04:21 PM   #8 (permalink)
Lowtorious's Avatar
Member # 2387
Send a message via AIM to Lowtorious
Originally Posted by Black-Widow
IROK Radials:
36x13.5x15 81lb
37x12.5x15 77lb
Say what, Beavis? It just doesn't make sense!
Lowtorious is offline   Reply With Quote
Old 06-23-2004, 11:03 AM   #9 (permalink)
Member # 32093
Lowtorious,
Per Interco that's what they said... I questioned it at the time and they double checked but that's what the spec sheet apparently said.... Go Figure....
Old 06-23-2004, 09:21 PM   #10 (permalink)
RockMolester's Avatar
Member # 28602
It makes perfect sense. All the weight of the radial tires is in the tread area, where the steel belts are located. The wider tire will weigh more than the narrower tire.
I have the 36x13.50x15 Irok Radials, and I've handled both the radials and the bias ply Iroks, and the radials are quite significantly heavier. Radials have a harder to puncture tread area and are much friendlier on the street, which is why I chose the radials over the bias plys, and I'm very happy with my choice.
2010 Jeep Rubicon: Daily driven rockcrawler
BlueRibbon Coalition: Fight to keep public lands open to the public!
RockMolester is offline   Reply With Quote
Old 06-26-2004, 08:31 PM   #11 (permalink)
Member # 32093
Just curious, Does anybody know the weight of a 37x12.5x15 GoodYear MRT? I am curious to see how it compares to the Irok Radial...
Thanks,
