Member # 34047
Pumpkin Angle
I am in the process of installing a 700R4 transmission and NP 208 transfer case in a 1969 Blazer. It will have a six inch suspension lift also. I am trying to get the motor as level as possible. Should I rotate the rear axle up toward the transfer case or leave it level? If I need to rotate it, how do I do that? Same question for the front. I thought I read some where that the u-joint connection at each end should be within 2 degrees of each other.
Member # 33838
if it has the slip yoke with only a ujoint at each end then the drive line angles need to be the same. 4 degree difference at the slip and 4degree difference at the pinion, for example. if you have a cv joint at the slip then the drive line should be straight with the pinion, 0 degree difference. use axle shims to adjust as necessary. get the angles as close as possibile when the rig is sitting flat on an even surface.
Member # 34047
So if there are u-joints at each end the angle between the driveshaft and either the transfer case or differential needs to be the same at each end. Is there a maximum angle to stay under? I think I may have to go with a cv joint off the transfer case forward just to clear the cross-member. The cross-member had to be relocated to line up with the support bolts. This brings up another question. Mid-eighties parts blow-ups show a rod from the side of the transfer case up to the bellhousing with no bracket to the side rail of the frame for support. When I got it, it had a NP205 with this bracket to the side. Do I need this side bracket or is the rod to the bell housing enough?
