Member # 14644
Running a shackle on one end of a trac bar
Does it still work well enough to run a shackle on the frame end of a trac bar to prevent axle wrap on a full size? It seems it would just want to push or pull the shackle as the axle rotates...or am I wrong?
Thanks Greg
1986.5 Nissan crawler - dual cases, one tons, 42's... 2003 SV650 1997 F350 DRW PSD |
Member # 1007
It shouldnt push or pull too much if you have a double trac bar setup (sams style). One will be pushing while the other is pulling. The solid mount of the spring also helps fight this.
[B][COLOR="Gray"][SIZE="4"][url]www.DLUXfab.com[/url][/SIZE][/COLOR] [/B] |
Member # 14644
do you have a pic of sams style? I'm not sure I see what you mean by a double.
Thanks!
Mr. Personality
Member # 11869
Im guessing youre talking about a traction bar , not a trac bar.
Here is the sams heavy duty traction bar. The way it is mounted , with 2 attachment points at the axle and the shackle set vertical at ride height , the axle cant pull or push the shackle forward or back... it can only try to compress or stretch the shackle , which it wont do. |
Member # 14644
ok cool, thanks! That's how I was going to build it, just trying to figure the logic...so the shackle in the front mount allows the flex for the axle movement as the shackle on the leafs pivot with rotation...I got it. Sweet! Thanks guys.
Greg
Member # 14644
would 1.5"x .120 wall DOM be suffcient? It's going in a blazer- 4" blocks, 350 sbc, locked, 35's. I think 1.75x.120 would be better, it's got to be pretty long, so it will be gusseted the whole way. /\/\/\/ What do you think? The guy wants it cheap as possible, and I've got some 1.5x.120 and 1.75x.120 DOM here already...otherwise, I have to order some thicker junk for $7-8 a foot. But I don't want to do it twice....
Member # 1007
You could get away with going all big like that but I liked to go smaller. I did mine out of 1" .25 wall. Nice, small and out of the way. Plus I just drilled out the end and tapped it for a 5/8" heim.
cheap is fine...mine was also 1" .25 wall, and tapped....
just make sure it's a full V design, a Y design will bend (been there, done that, have the busted pinion to show for it...)
Brian 'woody' Swearingen - IH8MUD Inc. '74 FJ40, '95 HZJ75, '96 FZJ80, '03 2500 DMax, '09 RZR |
