What brand and kind of oil do you run in your 4.0? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-25-2004, 06:44 AM   #1 (permalink)
Member # 34501
I am coming up on an oil change and i have been hearing alot about putting synthetic into the 4.0. I used to run full syn. in my VW GTI's but have been sticking with reg. 10w30 oil. I have about 116,xxx or so miles right now. What do you recommend and what are your experiences with both types of oil..thanks in advance!
97grntjsahara is offline   Reply With Quote
Old 08-25-2004, 07:02 AM   #2 (permalink)
MossMan's Avatar
Member # 11995
Send a message via MSN to MossMan Send a message via Yahoo to MossMan
I use vegetable oil :shrug:
MossMan is offline   Reply With Quote
Old 08-25-2004, 07:08 AM   #3 (permalink)
Member # 28248
DON'T DO IT!! I did in mine and had close to the same miles on mine and it made my engine knock. I don't know why I draned it back out and put normal oil in and it stopped. I talked to the guy at the parts store and he said unless it is a new engine or freshly rebuilt that sythetic was not a good choice, so I would not use it.
1994 YJ, 4.0l, ax15, Dana 300, Dana 60 locked front Dana 70 welded rear 5.13's, RCI fuel cell, cut fenders, BTF XJ spring kit with 4in springs in SOA, Ramsey Winch, working on cage and tube work to protect the body, hope to be back on the trail by early spring!
SMOR YJ is offline   Reply With Quote
Old 08-25-2004, 07:26 AM   #4 (permalink)
desmo888's Avatar
Member # 13824
Yeah - that's a good source, some dipshit making $6/hour at Pep Boys. Probably never bought a quart of synthetic oil in his freaking life!
Having said that, synthetic oil is better, no question. The problem lies in the trade off - i.e. oil leaks. My high mileage 4.0's have developed oils leaks after changing to synthetics. They don't leak a lot but it looks like a lot and spots your garage or driveway.
My current 4.0 is not leaking at 104k but it started on synthetic at 68k. Give it a try and see what happens, it certainly can't hurt.
desmo888 is offline   Reply With Quote
Old 08-25-2004, 07:30 AM   #5 (permalink)
Member # 15049
if you do switch over to full syn, do it over a few oil changes.
1986 K30
sw99 is offline   Reply With Quote
Old 08-25-2004, 07:33 AM   #6 (permalink)
Keith Strong's Avatar
Member # 477
Send a message via Yahoo to Keith Strong
Only the good shit
[CENTER][SIZE="5"][URL="http://www.strong-arms.com"]Strong Arms "Survival Slings" For Sale PM me for a PBB only price[/URL]
[/SIZE][/CENTER]
Keith Strong is offline   Reply With Quote
Old 08-25-2004, 07:35 AM   #7 (permalink)
Member # 28248
Okay we have our first dumbass in the discussion now, The dipshit was and ASE certified mechanic for the department of Trans. and knew what he was talking about . as stated above we first blended the oils and did it the correct was the is almost a 100k between your vehical and mine and his if you switch earlier the better but at least you were correct that it won't hurt anything just you pockets for 30 for the syntetic oil.
Old 08-25-2004, 07:36 AM   #8 (permalink)
Member # 27390
i use baby oil
[COLOR="Red"]"In vino, veritas"[/COLOR]
supernatural is offline   Reply With Quote
Old 08-25-2004, 07:37 AM   #9 (permalink)
Member # 28248
baby oil works too! hell just dont run any oil it adds weight
Old 08-25-2004, 07:42 AM   #10 (permalink)
Member # 10808
I can't believe I have to post this again...you guys should really start searching!
It's all about the Bacon Grease. Not only is it viscous, but when you park in your drive way it cools down and self-seals from leaks. Not to mention you can cook with it in a pinch.
Blah blah blah
1RUSTYRIG is offline   Reply With Quote
Old 08-25-2004, 07:44 AM   #11 (permalink)
Member # 28248
Bacon Grease.... I knew I forgot something!
Old 08-25-2004, 07:47 AM   #12 (permalink)
Bending light
BlueAngel's Avatar
Member # 24300
Do they make synthetic bacon grease too?
Project - Destroyer
BlueAngel is offline   Reply With Quote
Old 08-25-2004, 07:49 AM   #13 (permalink)
MC
MC's Avatar
Member # 21997
Send a message via Yahoo to MC
synthetic oil is NOT good for a rig with a flat tappet camshaft. If you run synthetic your lifters can stop rotating causing a flat spot of the lifter and uneven wear and eventually a lobeless camshaft. Their are oils that lubricated many times better than conventional motor oil out there but their is a reason they are not used. More nad more cam mfg's are telling their customers to avoid synthetic oil unless the factory reccomends it for your motor.
Industrial Quality CNC machines at a Hobby Price!
USA Quality is job #1
We build CNC plasma tables, click me
American Motors Engine HERE!!
1-651-257-7917
MC is offline   Reply With Quote
Old 08-25-2004, 08:05 AM   #14 (permalink)
Member # 34501
thanks for the reply's and the smartass ones as well:oP i mena if i stay on reg. oil till the engine dies vs. synthetic. Is the engine life going to change by switching oils?.....
Old 08-25-2004, 08:15 AM   #15 (permalink)
95steel's Avatar
Member # 14509
No, as long as you have changed your oil when you were supposed to in the past it will be fine. I wound up having to put rotella T 15-40 in my jeep to get me off the trail a few years back. That stuff will clean all the crap and sludge regular oil won't touch. I wound up leaving it in the jeep and have been using it ever since. I run the 10-30 visc in the winter and 5-40synthetic when I can afford it in the summer. Changing to synthetic will not harm your engine, synthetic oil will not cause oil leaks either, it just magnifies any leaks you already have. Putting synthetic oil in an engine with an oil leak is stupid, put cheap oil in it until you can fix the leak.
95steel is offline   Reply With Quote
Old 08-25-2004, 08:19 AM   #16 (permalink)
Member # 34501
ok, thats all i needed. to know. I am just gonna stick wth what i have cause i haven't had any problems. Thanks for all the info. I appreciate it
Old 08-25-2004, 09:01 AM   #17 (permalink)
ItsaCJ6's Avatar
Member # 6340
Location: Telluride CO, within site of of Black Bear Pass
Just for an FYI there are only three types of motor oil. Parafin based oils, Ash based oils and synthetic oils. As far as I know GTX and Penzoil are the only ash based oils. Synthetics have wildly variable formulas, and Parfin oils are the kind that leave gook in the engine over time. Ash based oils are the better choice of the two non synthetics.
Marc
In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good."
Super conversion calculator website
Love and kisses, Zaphod..
ItsaCJ6 is offline   Reply With Quote
Old 08-25-2004, 09:16 AM   #18 (permalink)
deadmeat's Avatar
Member # 21498
Here is a good read on oils.
Gear toward Motorcycles, but the info is still good.
deadmeat is offline   Reply With Quote
Old 08-25-2004, 09:21 AM   #19 (permalink)
Geesh's Avatar
Member # 4787
Send a message via AIM to Geesh
Funny, my friend's BMW motorcycle says specifically NO SYNTHETIC, while BMW autos endorse it . . .
wrapped in pleather
Geesh is offline   Reply With Quote
Old 08-25-2004, 09:34 AM   #20 (permalink)
Member # 34271
Royal Purple full synthetic and never looked back. i heard that inorder for an engine to properly " adjust" to a full synthetic you need to run a semi-synthetic first so i ran quaker 4x4 oil in it and that was good too, but my comanche knocks to shit anyways and nothing stopped that.
Rizon is offline   Reply With Quote
Old 08-25-2004, 10:15 AM   #21 (permalink)
Gun for Hire
jstandle's Avatar
Member # 17130
I prefer using straight power punch. Cost's a little more to change the oil, but I've only had to do it once in the 80,000 miles I've put on it.
Jordan
jstandle is offline   Reply With Quote
Old 08-25-2004, 10:28 AM   #22 (permalink)
95steel's Avatar
Member # 14509
Almost all mass produced motor oils sold in the usa are parifin base stock. Mobil one is the only "mass produced" group 4 synthetic, (I do not know about royal purple and red line but because of the price I would assume they are group 4). Pennzoil, QS, Valvoline, Castrol synthetics are all group three base stock (comes out of the ground and is then refined and somewhat engeneered) and then labled as synthetic. What is interesting is that Mobil one has developed the tech. to go from gas to liquid in a lab. Haven't heard anything else about it though.
In all truth, govt regs require all motor oils to exceed what we think they can do. An engine sludging up 99.9999% of the time is caused by a problem with the engine (coolant leak etc...) not the oil.
Old 08-25-2004, 11:40 AM   #23 (permalink)
MC
MC's Avatar
Member # 21997
Not entirely accurate, todays synthetics include esther which will eventually sweell the seal by replacing the natural oils in the seal and giving it its shape back if it isnt to worn away.
royal purple to my knowledge was a racing lube and had friciton modifiers in it, NOT GOOD FOR STREET MOTORS TO RUN FRICTION MODIFIERS. FM's cause alot of wear by having a unequal amount of larger sized molecules flowing around shear areas...do not use race oil in a streedt motor, your not doing yourself any favors
1-651-257-7917
Old 08-25-2004, 11:43 AM   #24 (permalink)
MC
MC's Avatar
Member # 21997
Not true either, a synthetic oil only leaks for the first couple of oil changes and you do not need to break in any engine to run synthetic. Due to the additive (which is neutral) Esther, the seal will swell if not broken down too bad
1-651-257-7917
Old 08-25-2004, 11:53 AM   #25 (permalink)
Mo
Everyday is Tuesday.
Mo's Avatar
Member # 47
Mo is offline   Reply With Quote
