Banned
Member # 24704
Actually, I just said that because you posted in all caps, which is generally considered annoying and yelling.
IF it is a real early (you didn't say what year) D60 it will have coarse spline axleshafts which will essentially make the whole assembly garbage. Find out what it came from exactly and I'm sure we can help you out. |
Burned
Member # 19879
i found out that
it has a broken shaft he was running 38 with a nine" and keeped rolling housings,shafts,etc. put this in and got rear ended and broke the shaft.I am planning on getting aftermarket shafts but the power lock is brand new
how great is a power lock should i just end up swapping carrier and shafts or leave it alone
IH/Rover Moderator
Don't think of it as a D60, but a D44 with a stronger R&P!
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working." BUY MY BOAT http://www.pirate4x4.com/forum/misc-...e-history.html |
Burned
Member # 19879
been searching
i am going to check the bom tomarrow 603043 is 69....-5 is 3.54 detroit no spin
-6 is 4.10 detroit no spin -1 open and all others are powerlocks the guy I might be buying from says it works great and got the rear end rebuilt with dana specs( ford people) it only barely unlocks around corners.My problem is does it have small bearing ends or will this thing hold up alright with 38's 4.88 and an axle snapping straight 6 i havent had a problem with my 8.8 detroit with 4.56 except i am worried about my saftey with c-clip axles but I am only running 35"krawlers
Burned
Member # 19879
tim84k10 does it matter how early ford they only had them 67-69 f100 ithink 81 had a 61 and the rest are mopar,j4000(i wish i could find one),dodge the only prob is the rest had 1.5 axles and the ford had 1 5/16 which i will be upgrading but coarse shafts?????i dont quite understand
Member # 17313
your worried about the C-clips breaking on a 8.8?(they don't it's only a jeep thing)
but yet you want to swap in another C-clip axle, with smaller shafts, less ground clearance, and the same pinion diameter... hmmm..
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
#12 (permalink) |
Burned
Member # 19879
I am new but not that new from my refrences 1980(i was close) had c-clip 60's and i think they are called 61's?i dont know much about 60's rebuilt my 70 rear in my d.d. but thats about as much as i know about danas except for 30's
