source of aftermarket turbo, CTD - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-11-2004, 10:25 PM   #1 (permalink)
Member # 2275
I am looking to replace the turbine housing on my dodge ramcharger swapped with a cummins turbo diesel. It has a major case of turbo lag. It came stock out of the donor truck with a 21mm turbine housing.
Searching locally I can only find a 18mm housing which is the other size that came stock. When I mention to the local shops that I have heard of people using 16mm turbine housings which are a direct bolt on application they tell me that I need to replace the entire turbo unit. I am under the impression that they are blowing smoke.
Anyone know where these 16mm units are available?
Matt
88 toy, SAS, fully locked, dual cases, longs- more tube needed.
2001, CTD quad cab
1992 yamaha basnhee.
Lookin' for stock A/C system for a 95, 22r, 2wd, r134 complete.
matt lytle is offline   Reply With Quote
Old 09-12-2004, 09:09 AM   #2 (permalink)
Member # 11760
try piers diesel service, he sold me my 16cm, he has great service and it was on sale 2 years ago.
87 zuk
horse_with_no_name is offline   Reply With Quote
Old 09-12-2004, 12:29 PM   #3 (permalink)
Member # 2275
How has that 16mm housing been for you? Do you find that it spools up too fast?
thanks Matt
2001, CTD quad cab
Old 09-12-2004, 03:04 PM   #4 (permalink)
Member # 18452
im replacing my 16cm turbo with a 9cm one. id sell it cheap.
1942 wc-53 4bt/4l80e d60/14b
mcinfantry is offline   Reply With Quote
Old 09-12-2004, 03:08 PM   #5 (permalink)
Member # 16468
Some good info here www.turbodieselregister.com
1969 Jeep M715 6x6 6BT/NV4500/NP202.5 D60/70/70
1963 Jeep J300, 4BT/NV4500/NP200/D60/60
Mikel is online now   Reply With Quote
Old 09-12-2004, 07:15 PM   #6 (permalink)
Member # 2275
Hey, Mcinfantry, how much are you willing to let it go for? Shipped to 90804?
How many miles are on the unit?
how does this unit do? spool up too fast? too slow? your impressions?
currently i am 410's and 33's, wanting to go 355's and 35's because my hiway RPM'S SUCK. E mail is down, call my cell 310 435 9800 if you wqant to pawn it off.
2001, CTD quad cab
Old 09-12-2004, 07:36 PM   #7 (permalink)
Member # 18452
im not quite ready. i run a 4bt (4cyl) with a 16cm housing. im going 9cm so it will HOPEFULLY spool faster. i gotta replace mine so i can sell the one on the truck now. its NON wastegated.
Old 09-13-2004, 04:30 PM   #8 (permalink)
Member # 19670
McInfantry, do you have your 9cm2 yet? I've got a spare HY35, wastegated and 9cm2 turbine housing, with the short sectdion of downpipe/casting.
72 Bronco, 4BTA Cummins/W propane, D60's/4 wh steer, 3 link rear, NV4500, , lots of other junk
CumminsBronco is offline   Reply With Quote
Old 09-13-2004, 04:46 PM   #9 (permalink)
Member # 18452
no,i dont have it... i need your phone number again. lets talk! pm me!
Old 09-17-2004, 01:01 PM   #10 (permalink)
ddestruel's Avatar
Member # 20999
check with high tech turbo out of Utah lots of cummins goodies www.htturbo.com
I AM ONE OF MANY WHOM WASHINGTON HAS CHOSEN TO IGNORE OR FORGET
But i Vote
GO UM Montana Griz
"Jeep Lurker"
KEEP REMEMBERING 9/11
Jeep with Rambler motor, SUA, front 608.9 and some bolt on stuff.
I miss my old 4bt powered chief
Support Frank the Tank
ddestruel is offline   Reply With Quote
