Member # 30179
4wd question
Hypothetical situation, If two different ratios are run in axles, how long, if any, could the truck be run in 4wd before any real damage?
1990 6.2 Diesel Suburban D60 welded 4.56 14bff welded 4.56 X-over 39.5 IROKs |
Member # 22799
Actually depends on a number of things. The main one being the surface. If you are on a high traction surface,
. If you are on a loose surface where the tires can scrub, you might be ok. The difference in ratios makes a big difference as well. There are some mud boggers that actually run a higher ratio (numerically lower) on the front so that the front end pulls them more helping with directional control.
-- Hero |
Member # 62
I think your 10 bolt wouldnt last. It would be trying to pull the rig along which would be a bad idea. I wouldnt push it, I know one person that ran 3.73 in the rear and 4.10's in the front for awhile. He ended up blowing up a rear AMC 20 shaft and the thing didnt have much traction in any situation because the rear tires were constantly in a state of broken traction.
Jeff Neves |
#9 (permalink) | |
Member # 26229
Still wiping my muffin off the computer!!! |
