hydro assist - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-28-2004, 11:44 PM   #1 (permalink)
Member # 29111
Send a message via AIM to tiny2085
hydro assist
I have a tapped box, and have a buddy that works at evco hoses, will this work for an 86 dually 60 for hydro help?http://www.surpluscenter.com/item.as...name=hydraulic is the stroke to short, it will be pushing 37's.?
To do something common, uncommonly good, brings success.
tiny2085 is offline   Reply With Quote
Old 10-29-2004, 10:18 AM   #2 (permalink)
jopes's Avatar
Member # 8469
Send a message via ICQ to jopes Send a message via AIM to jopes Send a message via Yahoo to jopes
all I am going to say is that cyclinder is probably not going to have much force to aid you in turning.
408ci SEFI, 70mm throttle body, 90mm mass air, stang harness, tweecer R/T waiting on a home.
jopes is offline   Reply With Quote
Old 10-29-2004, 03:19 PM   #3 (permalink)
Member # 14367
Send a message via MSN to myeyesore
Save yourself a lot of headache and get the a ram with heim ends.
myeyesore is offline   Reply With Quote
Old 10-29-2004, 09:42 PM   #4 (permalink)
wildgoose's Avatar
Member # 24819
Check out www.rocklogic4x4.com they have a whole kit for about 220 bills that works great.
One tons, Hummer wheels, yada,yada,yada
wildgoose is offline   Reply With Quote
Old 10-29-2004, 10:24 PM   #5 (permalink)
Member # 29111
thanks guys, I was just trying to save a little $$. You know what i mean? thanks for the link goose.
Old 10-30-2004, 01:07 PM   #6 (permalink)
Member # 11998
Send a message via AIM to BrettM
i got that exact ram from Surplus center, I'm adapting it for rod ends. I am running 35s, and WILL NOT go bigger than 35s, so I think it will be fine. I just want a little extra strength in the steering, and more importantly to take some stress off the frame; so I think this will be a good ram for me.
For something with a 60 front and 37s I'd go with a 1.5" bore ram, like this one: http://www.surpluscenter.com/item.as...name=hydraulic or this one: http://www.surpluscenter.com/item.as...name=hydraulic
I measured how much my tie-rod moves from lock to lock on my D44, and the 7.5" stroke of my ram will probably just barely limit my steering angle. Measure from lock to lock at your mounting points to figure out how much travel you need.
here's a thread that I asked about the 1.125x7.5x.75 ram: /forum/newbie-general-4x4-discussion/249847-hydro-assist-has-anyone-used-ram-smaller-than-1-5-a.html
awshifting.com
awshifting@gmail.com
BrettM is offline   Reply With Quote
Old 10-31-2004, 06:57 AM   #7 (permalink)
Member # 26894
Send a message via ICQ to Smash-K20
Ok not that I am an expert on steering, but I know alot about Hydraulic systems. As long as the flow volume from the pump remains the same a smaller diameter cylinder will turn the wheels faster but with less power, a larger diameter cylinder will have more power less speed.
Brett M, I just thought I should mention you do not want to have your cylinder limiting your steering in any way, especially at the end of the cylinders stroke. Loaders and dozers all have stops on them to prevent this because cylinders do not like to be over extended. It will eventually take the seals and cap out of the end of the cylinder. If you must use a short cylinder then you are better off to set your stops back alittle more then where the cylinder ends, your best bet is to get a cylinder that has a slightly longer stroke then you need.
Dale
_____________________________________________
[QUOTE=Entropy]Please, Rip isn't big enough to make me mumble. I could sing the Star Spangled Banner without a skip sucking Rip's dick.[/QUOTE]
Smash-K20 is offline   Reply With Quote
