dual shackles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-22-2004, 11:52 PM   #1 (permalink)
crawlinyjeep's Avatar
Member # 29220
Send a message via AIM to crawlinyjeep
dual shackles
ive seen all those toyota pu's with the two shackles on the rear and i got the shackles to do that but do i wnat to do it on my yj (has anyone done it before? if so what happened?) thanks
92 3/4 ton yj stretched locked up on 44 14.50 20 bling bling rolled at seventy daily driven
crawlinyjeep is offline   Reply With Quote Quick reply to this message
Old 11-23-2004, 05:39 AM   #2 (permalink)
Member # 20374
Send a message via AIM to Grapehead
the point of haveing one end of the leaf spring fixed to the frame is to locate the axle.
if you go to dual shackles you will have to link it to locate the axle since the springs will no longer do it.
theres a rig in the new JP with this setup.
you just don't mess with a man's alcohol. *shakes head disapprovingly* when are people gonna learn?
[QUOTE=Harry Johnson]If Jesus reads pirate4x4, we're ALL screwed.[/QUOTE]
Grapehead is offline   Reply With Quote Quick reply to this message
Old 11-23-2004, 08:36 AM   #3 (permalink)
Member # 18419
Send a message via AIM to 65cruiser
do you really have the stuff because i've seen you selection and its kinda grim. make sure you do it right don't booty-fab the suspention its too important to have somthing go wrong. And "grapehead" thanks for all the input here and on the charging post (that was my truck) but i beleve hes talking about the tara-flex type shackle where there are two shackles folded up on the back mount of the spring so they can unload and give more droop.
Gravity - Use it wisely
65cruiser is offline   Reply With Quote Quick reply to this message
Old 11-23-2004, 08:59 AM   #4 (permalink)
Member # 20374
oh ok,. now i see.
like those revolver shackles or something? i thought the general consensus was that they were crap.
Old 11-23-2004, 09:20 AM   #5 (permalink)
Member # 30954
Send a message via AIM to Prerunner1982 Send a message via Yahoo to Prerunner1982
pick up the Dec 04 issue of 4wheel and Off road, they have a YJ that they did a spring over with dual shackles...
Prerunner1982 is offline   Reply With Quote Quick reply to this message
Old 11-23-2004, 11:44 AM   #6 (permalink)
Member # 29220
no no no i am talking about runnig two shackles on the same side of the spring so then its almost like a revolver. i just got them laying here and someone wants to buy them. should i sell or through them on.
Old 11-23-2004, 11:56 AM   #7 (permalink)
Member # 33382
I belive this is what he means.
well something like this
Steppy is offline   Reply With Quote Quick reply to this message
Old 11-23-2004, 05:58 PM   #8 (permalink)
Member # 4836
The only reason you've 'seen' these dual shackles on Toyota's, (like the one above Steppy has shown), is because those Toyota's have the 63" Chevy rear spring swap. and since the bolt diameters differ between chevy and Toyota, and the top of the Chevy just happens to fit into the bottom of the existing Toyota shackle, it's easier...
Thats it. You will obviously get more suspension travel with 2 shackles, but the 2 shackle thing is a passing fad.
FZJ80 40th - TLCA #8958
1984 4runner; rubicon tested mother approved SOLD
84runner is offline   Reply With Quote Quick reply to this message
Old 11-23-2004, 07:11 PM   #9 (permalink)
Member # 29220
yea i got ya the things i was thinking about were shitty shackle angle now and that would fix that #2 is it would give me more down flex witch is somethin i need with 2 inches of down travel now anyway thanks
Old 11-24-2004, 02:54 PM   #10 (permalink)
87JeepWrangler's Avatar
Member # 13959
Send a message via AIM to 87JeepWrangler
man, talk about bad spare tire placement
rob
87JeepWrangler is offline   Reply With Quote Quick reply to this message
Old 11-24-2004, 04:28 PM   #11 (permalink)
luigi's Avatar
Member # 2375
I think thats a fad I like, look at the suspension on this bitch. It has a double shackle and a twisty.
webilt.com
luigi is offline   Reply With Quote Quick reply to this message
Old 11-24-2004, 04:43 PM   #12 (permalink)
Member # 35034
I've had no experiance with these but I bet they will give you a hell of time when you are going up and down a hill. They will tend to load/unload at the wrong time and make for a not-so-fun ride. Search for the revovler shackle. People complain about these things loading/unloading at the wrong times.
95 Bronco on bags
kstatecruiser1 is offline   Reply With Quote Quick reply to this message
Old 11-24-2004, 06:07 PM   #13 (permalink)
Member # 23514
FSJ guys have been using the Teraflex Revolver shackles.
A lot of guys have been having problems with them loading / unloading on hills and sidehills.
Be careful, they are a bit scary when they unload unexpectingly.
I know a guy that rolled his Wagoneer because of his revolvers on the front of the Jeep unloaded on a sidehill climb.
I think you could get plenty of flex by running stock springs SOA instead of these "revolvers".
greentj is offline   Reply With Quote Quick reply to this message
Old 11-24-2004, 06:46 PM   #14 (permalink)
jvmin's Avatar
Member # 23417
2 inches of down travel sounds like you haven't unhooked the swaybar. or your shocks are too short or something.
so if you jack your rig up by the frame it droops 2 inches from where it runs at drive height? then your wheel is coming off the ground?
and let's just say that the double shackles are exciting at times to say the least.
Joint Venture Ministries
jvmin is offline   Reply With Quote Quick reply to this message
