Shock Question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-04-2005, 07:52 AM   #1 (permalink)
Member # 13891
Shock Question
I did some searching, but I am lazy so I will just ask. My friend wants to buy some new shocks. Money is not an issue. He has a TJ with currie 9" in front and currie 60 in back. He has a 6.5 rubicon long arm lift. Ram Jet 350. He has the Old man emu shocks right now. He says they feel to soft. He drives his jeep some on the road, but mainly on rocks, but not extreme rocks. Any suggestions. i told him I would find what he need. I was kinda leaning toward Bilstein. Thanks
olemiss is offline   Reply With Quote Quick reply to this message
Old 02-04-2005, 09:40 AM   #2 (permalink)
Geesh's Avatar
Member # 4787
Send a message via AIM to Geesh
I am leaf sprung, but I bought a set of Fox 2.0 Series emulsion shocks. Main reason is because I want the ability to rebuild on my end. Should the damping not turn out, I can change the shim pack and dial it in. This does require you to have compressed nitrogen on hand for the 200psi required pressure. A small tank rental provides that.
But since money isn't an object, I'd spring for the 2.5 series with remote reservoir cause they look cooler . . . .
wrapped in pleather
Geesh is offline   Reply With Quote Quick reply to this message
Old 02-04-2005, 07:16 PM   #3 (permalink)
Member # 62
money is no object I would go with something like bilstien 7100..
Bilstien 5100 are probably more then enough however
Jeff Neves
NE-RokToy is offline   Reply With Quote Quick reply to this message
Old 02-04-2005, 08:29 PM   #4 (permalink)
Member # 13891
Rubicon shocks
He bought those Rubicon shocks with the remote resavoir. Don't no to much about them, they were about $159 each.
