detroit locker passing the buck? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-07-2005, 06:38 PM   #1 (permalink)
Member # 41291
Hi out there, I'm a fawking newbie, so forgive my first thread. I have a 1997 tj with a 35 rear end and a super 35 kit. I just put the locker in it 14 months ago and it failed. The nobby gears inside stripped clean off, and the rest of the rear end was in good shape! I called detroit first about their $602.00 price tag for a locker, and then about some kind of warrantee. They told me ver batem that the model 35 was a VERY unreliable rear end and that diff breakages were common. I have been jeeping for 16 years and have never heard this! Can anyone out there agree with this statement or agree with me that they are making junk and selling it for top dollar!
highroadconstruction is offline   Reply With Quote
Old 02-07-2005, 07:36 PM   #2 (permalink)
Member # 20592
Send a message via AIM to gumbojeepyj Send a message via Yahoo to gumbojeepyj
Why YES!!! I can confirm that the Dana 35 is a complete piece of shit!
Blake
http://www.lockitupoffroad.net
gumbojeepyj is offline   Reply With Quote
Old 02-07-2005, 07:40 PM   #3 (permalink)
El Guapo
TexasBlake's Avatar
Member # 9722
I run a Dana 35 with 53" Michelins powered by a Rolls Royce V12 and have never had a problem. Of course, the Detroit locker I run in it is custom machined out of Kevlar coated Titanium, was yours? That might by way it broke.
You might want to try to add torque tubes from a U404 to the axle, that way it will act as a third link to stop axle wrap.
The Dana 35 is so badass, I even made a front Dana 35. I put on the inner Cs and knuckles from a Dana 30 to make a my own Dana 32.5
TexasBlake is online now   Reply With Quote
Old 02-07-2005, 07:44 PM   #4 (permalink)
Member # 18601
I BELIEVE THAT IS CALLED POLISHING A TURD
88YJ
67M715
00Excursion 7.3
SVENG52 is offline   Reply With Quote
Old 02-07-2005, 07:53 PM   #5 (permalink)
El Guapo
TexasBlake's Avatar
Member # 9722
This just in:
My buddy broke his Dana 35 last night doing a burnout. He has a 2.5L and 30" BFG mud terrains.
Old 02-07-2005, 08:30 PM   #6 (permalink)
HeiserOilMotorsports
Po' riggity's Avatar
Member # 1515
Send a message via AIM to Po' riggity Send a message via Yahoo to Po' riggity
Don't even try to blame this crap on Detroit locker. Ive talkd to one person in particular at tractech quite a few times, and you should know by now that a D35 is prone to breakage when being locked. Sometimes its the axle or housing, sometimes its the diff or locker. Suck it up.
Scott
HeiserOil Motorsports:
Crawlin' For Crohn's
Friends of San Bernardino National Forest (website not yet complete),
brought to you by Sbwinvps
Originally Posted by Alpine4x4 View Post
y'all know my flatbill hats make me the best desert racer out there!
Po' riggity is offline   Reply With Quote
Old 02-07-2005, 09:08 PM   #7 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
no matter how weak the stock axle is, its the after market part that broke THAT is the bull shit.
should have welded it!
Old 02-07-2005, 09:13 PM   #8 (permalink)
Member # 20592
doesnt matter, he's the dumbass that put the turd polishing kit in a
D35, im sure the housing got tweaked and the odd assed loads it saw broke something in the detroit.
Blake
Old 02-07-2005, 09:43 PM   #9 (permalink)
GaryTJ's Avatar
Member # 36995
I agree. If the detroit went and the axles are ok, the housing is bent. Pull it apart and weld the side gears in and you have a very expensive spool... Drive it until you get the money to go stronger.
Life is not about a pretty body, it is about sliding in at the end, all used up and worn out, going "Man, what a ride!"
GaryTJ
GaryTJ is offline   Reply With Quote
Old 02-07-2005, 09:49 PM   #10 (permalink)
Member # 28566
It's just God's way of telling you that you need to ditch the 35. Don't argue with
God.
LilRocky is offline   Reply With Quote
Old 02-07-2005, 10:00 PM   #11 (permalink)
Member # 27549
Send a message via AIM to Majo
12:59 AM Eastern
TUESDAY
2/8/05
Majo is offline   Reply With Quote
Old 02-07-2005, 10:31 PM   #12 (permalink)
Member # 62
exactly its more then likely not the detroits fault it broke... its the puny dana 35 housing.
Jeff Neves
NE-RokToy is offline   Reply With Quote
Old 02-07-2005, 10:35 PM   #13 (permalink)
Member # 20592
Originally Posted by Majo
12:59 AM Eastern
TUESDAY
2/8/05
Well I be damned, it sures enough is isnt it?!
Blake
Old 02-08-2005, 10:11 AM   #14 (permalink)
Mo
Everyday is Tuesday.
Mo's Avatar
Member # 47
Mo is offline   Reply With Quote
Old 02-08-2005, 02:20 PM   #15 (permalink)
Clean RC's Avatar
Member # 27103
Well first of all.... I think Superior is responsible for the failure...they manufacture and sell the product - so they are liable...contact them and ask what they are willing to do for you..
Second...never run a chromo shaft with any detroit product, the locker will blow up with too much shock loading. Your better off going back to stock axles and a limited slip in the D35 if that is what you choose to run..
I hope you are able to get this sorted out, good luck....
Clean RC is offline   Reply With Quote
Old 02-08-2005, 02:34 PM   #16 (permalink)
85GAJEEPCJ7's Avatar
Member # 27047
No offense dude, but don't you run a d-35C?
85GAJEEPCJ7 is offline   Reply With Quote
Old 02-08-2005, 08:59 PM   #17 (permalink)
Christian hater arg!
CrustyJeep's Avatar
Member # 29527
This IS a good point... The Dana 35 is known to be weak, you'd think the Detroit would be stronger than the shafts. This isn't the only Dana 35 Detroit I've heard of blowing up, either.
Then again, maybe the housing flexes enough to take out the Detroit?
Bottom line here though, DO NOT POUR MONEY INTO A DANA 35.
CrustyJeep is offline   Reply With Quote
Old 02-08-2005, 09:04 PM   #18 (permalink)
Member # 20592
i sure do, with an open diff and a bent housing.
Its replacement is coming quite soon.
Blake
Old 02-08-2005, 11:22 PM   #19 (permalink)
Member # 14781
If all dana 35 look like this I would say the same, but they don't so I will say it the Dana 35 is crap, crap and more crap.
Joe Rojas
1994 Cherokee XJ
roknxj is offline   Reply With Quote
Old 02-09-2005, 01:19 PM   #20 (permalink)
Member # 24475
Send a message via ICQ to JeffsJeep04 Send a message via AIM to JeffsJeep04
This just in:
I'm more curious on getting a 4 banger to do a burn out then him breaking the 35...hell, anyone can do that!
2000 WJ Limited 4.7 quadradrive
JeffsJeep04 is offline   Reply With Quote
Old 02-14-2005, 01:00 AM   #21 (permalink)
Member # 40037
d35 is the biggest pile of sh*t
i work at a rear end shop. the d35 is the week link period no matter what u do to it. and as for superior be responsible i dont think so im running a detroit with the superior shafts and i have never had a problem. the d35s are prone to either bend the housing,break shafts or destroy the carrior. from the sound of things u might have bent the housing. take it out of the truck and see if it is bowed. if it is its not the parts that u bought that caused the problem its ur fucking houseing. u should just chuck the piece of shit and get a ford 8.8 u will be alot happier.
master94546 is offline   Reply With Quote
