Member # 34837
which k5?
Before I start I just want to say hi as I am a newbie to this forum. I used to have a newer chevy 3/4 ton 4x4 but the ifs couldnt handle much wheeling
. Ive always loved the k5's and I want to have a sfa truck for my 4wheeling pleasure. My question to you guys is what year k5 to look for and why ? Im not too familiar with older vehicals so I figured you guys could point me in the right direction. Thanks in advance |
Member # 3645
Pretty much any k5 is the same. The 73's and newer have a large aftermarket support for body panels and shiat.
I'd look for fuel injected (I believe 87? and newer) and run it. Good luck. |
Member # 37553
87 and up are fuel-injected, but you have to deal with 10 bolt axles front and rear and a 208 tcase with a slip yoke. If you plan on an axle swap, then no big deal. 73-78 came with Dana 44 front, 12 bolt rear, and some had gear drives tcases (205). Pretty stout from the factory for light to mid wheeling.
Check out http://www.coloradok5.com/specs.shtml for the factory specs of every year of the K5.
I find that immaturity trumphs professionalism anyday |
Member # 34837
Thanks for the info, I do plan to swap in a 14b/d60 combo if i get one so ill definately be looking for an 87-up. I plan on using this rig to teach me how to work on truck so ill be doing most of the work on it myself if I can. That means I should get the truck this summer and be done 2035. Thanks for the link also, that has a ton of info.
BTW would those military k5's be somethin to look at? CUCV I think is the name of them with beefed up axles? I figured the good old boys at the base prob beat the crap out of them so I doubt anything would be in good shape. |
Member # 4737
military blazers had the 6.2 diesel blazer which was a bit under powered. the 89-91 k5 blazers are fuel injected sfa but have the newer 241 transfer case that there is sye kit for.
1989 Chevy Blazer 350 V8 |
#7 (permalink) | |
j
Leftists have killed 100,000,000+ people... still think its a good idea? [url=http://community.webshots.com/user/jekbrown]my 85 K5[/url] |
