Chevy D60 outers into a Ford D60?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-20-2005, 08:03 AM   #1 (permalink)
Member # 43299
Hello All,
I came across a brand-new in box Chevy 35-spline outers and picked them up for next to nothing... ok $50 for the pair... I want to know if I can install them in my Ford D60 which came out of a 79 F350.
I have heard the Chevy outers are different from the Fords, but in what way? Length? I plan on using Warn drive flanges.
-Steve
CrazySteve is offline   Reply With Quote
Old 02-20-2005, 10:28 AM   #2 (permalink)
Member # 22345
Yep, the length is different. The chevys are longer by.6" (D60 bible). You might be able to machine them down and put in a new groove for the snapring (depending on how long the splines are). I have some 30 spline ford stubs I'll be more than happy to trade for your 35 spline chevys!
Balsax is offline   Reply With Quote
Old 02-20-2005, 11:56 AM   #3 (permalink)
Member # 39679
Send a message via AIM to Skedar2
to make them fit you would have to also run chevy knuckles and spindles, or just dril chevy spindle to fit a ford Knuckle, then you would need to purchase some 35 spline hubs. I have seen some ppl shorten the chevy shafts, but then the spline contact is minimal and you just created a weak point (30 spline stock would probably be just as strong in this case.)
1977 F-250 Highboy, 429 dove-c heads ported polished with large valve job, L@L headers, 6 " suspension 2", 42 " swampers, 205 divorced t-case, C-6, 60's front and rear (rear detroit, powrlok front), 4.56 gears
Skedar2 is offline   Reply With Quote
Old 02-20-2005, 04:21 PM   #4 (permalink)
REDDMANIAC's Avatar
Member # 5733
I know the answer is in a search, cut down stub, regroove for snapring, presto!
REDDMANIAC is offline   Reply With Quote
