Can/should I beef-up a Dana 30? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-17-2002, 11:10 AM   #1 (permalink)
Member # 9298
If I upgrade the axles (Warn's), Hubs (Warn's), and U-joints (CTM's), can I make a Dana 30 just about as strong as a built Dana 44? Where would the week point be (the hub, right)? I would think this would be a very ecconomical way to run ~35"s without breaking (compared to having a complete 44 or 60 built). What do you think?
newt is offline   Reply With Quote
Old 02-17-2002, 11:50 AM   #2 (permalink)
XtrmTJ's Avatar
Member # 939
Little botton , upper right hand corner..." SEARCH " ! FNG !
__(OIIIIIO)__rOkOn
I am a Sheep Dog, ... Wolves Beware !
XtrmTJ is offline   Reply With Quote
Old 02-17-2002, 12:28 PM   #3 (permalink)
Member # 232
Send a message via ICQ to JIM3030
Re: Can/should I beef-up a Dana 30?
[no way. I ran 35's for a little while but with no locker. and if you try to drive over a stone you will be straightening and strenghtening your tie rod
86 CJ7 35" tires
JIM3030 is offline   Reply With Quote
Old 02-17-2002, 01:26 PM   #4 (permalink)
Member # 792
lets look at all the screwups so far
1) (obviously) you didn't search or you would have found a thread less than 2 weeks old on the same subject
2) you cross posted the same Q in the jeep and the general boards
3) you didn't say what kind of a dana 30.
01 TJ
Dan-H is offline   Reply With Quote
Old 02-17-2002, 01:34 PM   #5 (permalink)
Member # 792
http://www.pirate4x4.com/forum/showt...threadid=30856
01 TJ
Old 02-17-2002, 03:07 PM   #6 (permalink)
Member # 9298
I did do a search before I posted this and found almost no information. There was plenty of BS and "don't do anything smaller than a D60," but almost no actual information. Thanks for that one link. I didn't find it in my search. It had some nuggets of info hidden w/in all the crap.
I'm talking about a CJ Dana 30. Aren't the knuckles the same (30 vs 44)? It just seems like such a waste to buy a 44, narrow it, and fill it with all the "good parts" if it won't be any stronger than a 30 with the same "good parts". Apart from the axles, hub, and Ujoints, what is the real benefit of the 44 over the 30?
I may be 'new' but I'm trying to learn. Does any one have the answers to my questions?
Old 02-17-2002, 03:36 PM   #7 (permalink)
TRD
TRD's Avatar
Member # 8286
concidering my friend just blew out his D44 with 31's i wouldn't mess with a D30
-Ryan
TRD is offline   Reply With Quote
Old 02-17-2002, 03:58 PM   #8 (permalink)
Member # 9328
What you suggest doing will give you some additional strength, but there is one big problem there is no way around. If you go with decent gearing, say 4.56, 4.88 or better, your pinion gear to ring gear contact is PUNY , you will have a half a tooth contact at any one time on a very small R&P, a recipe for disaster.
"Somewhere. Out there. Is a big ass forest of weed"--Thomas Edison (from Rolling Kansas)
landusepbb is offline   Reply With Quote
Old 02-17-2002, 04:35 PM   #9 (permalink)
ROCK & ROLL OFFROAD
Member # 3906
Send a message via AIM to Jeepmangled87
dont waste the cash either keep the dana 30 stock and leave it alone, or go to a Dana 44 beefed up or even a front Dana 60 if you got the cash but dont waste your money on overpriced Dana 30 bullshit.
Jeepmangled87 is offline   Reply With Quote
Old 02-17-2002, 06:52 PM   #10 (permalink)
HeiserOilMotorsports
Po' riggity's Avatar
Member # 1515
Send a message via AIM to Po' riggity Send a message via Yahoo to Po' riggity
Wow... lots of opinions here.. Im planning on sticking some 297 u joints in my D30.....
UNTIL I CAN AFFORD A 44 FRONT!
Scott <><
HeiserOil Motorsports:
Crawlin' For Crohn's
Friends of San Bernardino National Forest (website not yet complete),
brought to you by Sbwinvps
Originally Posted by Alpine4x4 View Post
y'all know my flatbill hats make me the best desert racer out there!
Po' riggity is offline   Reply With Quote
Old 02-17-2002, 09:03 PM   #11 (permalink)
Member # 5510
with the 297X's in the 30, the 44 won't be an upgrade.
Lewis'Cutter'Jones
Moab, Utah
'99 Disco II TReK and some other junk...
www.anasaziexpeditions.com
www.moabslickrockhouse.com
Cutter is offline   Reply With Quote
Old 02-18-2002, 09:26 AM   #12 (permalink)
Member # 5960
Send a message via Yahoo to LAME
Originally posted by tj7
dont waste your money dude,and do not put in lock outs you will tightening all day long (the bearings that is)i have a high pinion 44 on ebay if you want take a look at it i even have the matchinf 9 inch to go with it ....
http://cgi.ebay.com/ebaymotors/aw-cg...tem=1805025370
http://cgi.ebay.com/ebaymotors/aw-cg...tem=1805031689
Sell him your t-case while you are at it
crawl4cure.org
Rock Rash Racing #613, Trail Tampon Spotter
LAME is offline   Reply With Quote
Old 02-18-2002, 09:33 AM   #13 (permalink)
tj7
Member # 6425
what ever he wants i have a couple of them lying around if he wants to do that...
tj7 is offline   Reply With Quote
Old 02-18-2002, 09:50 AM   #14 (permalink)
NothernAZxj's Avatar
Member # 8528
So your friend needs to learn to drive....whats that got to do with this post.....
Brian Harmon
NothernAZxj is offline   Reply With Quote
Old 02-18-2002, 10:57 AM   #15 (permalink)
Member # 1515
Thats not necessarily true... you get 3 more splines with the 44, a stronger housing, and a bigger ring and pinion.. thats an upgrade in my book..
Scott
Old 02-18-2002, 01:10 PM   #16 (permalink)
Member # 5577
Scott
Don't forget the thicker tubes, bigger spindles, bigger steering gear, bigger tie rod ends, bigger balljoints, bigger brakes, and bigger bearings.
Yeah, I'd definitely say the 44 is an upgrade.
It's all here before your eyes / Safety is a big disguise / That hides among the other lies
Jakesteramalamajama is offline   Reply With Quote
Old 02-18-2002, 06:11 PM   #17 (permalink)
Member # 5374
What a topic
I scan down the list of topics and click on ones like these when I need a good laugh
CJ5 with stuff...
Meyer is offline   Reply With Quote
Old 02-18-2002, 06:40 PM   #18 (permalink)
Member # 9328
What's so fricking funny about this topic. Sure its been asked before, but not everyone can afford time or money wise a completely different diff in their vehicle. Its people like you that are a joke if you can't understand that. The point is this guy wants to wheel, and do the best with what he's got, can afford, and can do.
Old 02-18-2002, 07:17 PM   #19 (permalink)
Member # 2095
You can probably pick up a 44 & have it shortened for the $$ you will put into your 30
'79CJ5,soa,d44/60,t18,d18w/Obrian 3.6low,5.13's,35x14.5SSR's
'02 Z71
CJ-Jeeper is offline   Reply With Quote
Old 02-19-2002, 08:30 AM   #20 (permalink)
Member # 1980
I ran 38X14.50 with Ox locker and 4:88 R/P with my 30 and 35 with detroit on the rear on my TJ, I have no problems. I've been to hard trails, you just got to know how to drive it. I've seen people with 60 and still breaking it..
ROKCRAZ is offline   Reply With Quote
Old 02-19-2002, 10:34 AM   #21 (permalink)
Member # 2665
Hey Brad,
Ease up a bit. The guy is new and just trying (albeit a poor attempt) to fit in. I think he was refering to the flame crap at the start of this post that's all.
As to the Dana 30, I would not waste the money, put the money you want to spend on fixing up the 30 into the bank and keep saving, so when you break the 30, you can replace it with a D44 or something better. A piece of shit in a tuxedo, is still a piece of shit.
Who Dares Wins
Jeep: It does the body good.
Live Free or Die.
MadMan is offline   Reply With Quote
Old 02-19-2002, 10:42 AM   #22 (permalink)
Member # 5510
bigger, but not a bunch stronger...
Lewis'Cutter'Jones
Moab, Utah
Old 02-19-2002, 11:39 AM   #23 (permalink)
Member # 10103
Send a message via Yahoo to pari_tj
I just have this to say, yes I am newbie to this board but not to jeepin. I have a '98 TJ that I have been wheeling hard in clayton, ok. I have ran just about every trail there many times.
I have a upgraded D30 and have no problems, i think it is all a matter of who you drive it. I have ran boggers and Xterrain tires with no difference.
You read my signature and see what I have done, with no breakage. I don't even run CTM's yet.
Paris_TJ
'98 TJ 4.0L, Auto, D44 Rear with OX, D30 Front with OX, Warn Inner Axles, Warn Hub Conversion, Warn 9500i, Borla Header, Flowmaster, 35" Xterrains.
pari_tj is offline   Reply With Quote
Old 02-19-2002, 11:40 AM   #24 (permalink)
Member # 7287
And replacing blown axles due to exploding u-joints on a 44 is better than doing the same on a 30 how?
Come back here, so that I may brain thee!
Welby is offline   Reply With Quote
Old 02-19-2002, 11:48 AM   #25 (permalink)
Keith Strong's Avatar
Member # 477
Send a message via Yahoo to Keith Strong
You are talkin affordable, and what you say makes sense, but from how I am understanding him he wants to spend a BUTTLOAD of money on the D30
[CENTER][SIZE="5"][URL="http://www.strong-arms.com"]Strong Arms "Survival Slings" For Sale PM me for a PBB only price[/URL]
[/SIZE][/CENTER]
Keith Strong is offline   Reply With Quote
