Window Licker
Member # 34948
6 lug knuckles/spindles w/ 5 lug hubs?
Is there any way to do it?
I've already got newly rebuilt chevy flat tops that have been milled/drilled/tapped and now I've decided to go with a 9" in the rear...so I need to get 5 lug in the front to match. Am I screwed and should I start looking for some ford flat tops or is there a way around it? |
you can swap on 5 lug hubs if your spindles are the big bearing or you can have your hubs and rotors redrilled for 5 lug .... I have redrilled a lot and for me it has worked GREAT..
Not to be a jurk but if you type in the search what your looking for a TON of stuff well come up on it. It gets posted a lot |
Member # 4790
True, a search would have helped, but to answer you question: you need pre ~74 Chevy/full size Jeep large bearing spindles (the step between the outer wheel bearing and the inner is no more than 1/16" or so, it it very different than the small bearing ones), Chevy brake backing plates, Chevy brake calipers, and mid 80's Ford F150 hub & rotors. This combination will give you a 5 on 5.5" bolt pattern with you flat top knuckles. Good Luck.
86 Sammy, spring over, 5.38 D44's, 36" SX's, 6.5:1 twin sticked T-Case, full cage, and a cooler full of beer so I can think straight!!! |
#4 (permalink) | |
Member # 1533
The correct years are '74-77 Chevy/full size Jeep. |
Window Licker
Member # 34948
Sweet - thanks for the info! I was hoping there would be a relatively cheap and easy solution to this - already dropped over $200 getting the chevy knuckles rebuilt.
I take it this is a big bearing spindle? |
#7 (permalink) | |
Window Licker
Member # 34948
Not sure I get the reason for using the big bearing spindle. Or is the mid-80's hub/rotor different from earlier fords?
I have been searching for the past couple days but everybody seems to say something different. I found this one: Quote:
Member # 20999
IIRC the dodge rotors and hubs with dodge backing plates can be used with big bearing spindle. Now i could be wrong with saying this but that rings a bell. otherwise turn the big bearing spindles down to fit the Ford/ and pre 77 jeep bearings and put the 79-85 and a few more years around there ford hubs and rotors on and uses the jeep chevy backing plates and calipers
http://www.jeepgod.net/d44625.html
I AM ONE OF MANY WHOM WASHINGTON HAS CHOSEN TO IGNORE OR FORGET But i Vote GO UM Montana Griz "Jeep Lurker" ![]() KEEP REMEMBERING 9/11 Jeep with Rambler motor, SUA, front 608.9 and some bolt on stuff. I miss my old 4bt powered chief Support Frank the Tank |
Window Licker
Member # 34948
But what's the point of the big bearing spindles in the first place? I already have a set of small bearing ones and I'm seeing conflicting posts that say they will or will not work.
The way I'm reading it I'll have to have the big bearing ones machined down to fit....seems like extra work if the small bearing ones will work from the start. |
Member # 1533
The confusion may lie in the descriptions you're seeing. The big bearing spindle has the smaller diamter for the inner spindle. The big bearing spindle has a smaller inner diameter. It is the one that the Ford hub fits on. The other spindle has a bigger diameter for the inner bearing, but the bearing itself is smaller with a larger ID.
You don't machine down a big bearing spindle as it's already smaller in diameter where the inner bearing sits. Does that help? |
#11 (permalink) | |
Moderator
Member # 20587
No, No, No.
You want a '73 to '76 (not 76.5) GM/jeep SMALL bearing spindle to use the Ford 5on5.5 hubs. In 76.5, jeep went to the "large" bearing spindle and hubs. Search. Or just look Here (From Mr. N's site) Quote:
kris.
. Ultra4 Stock Class #4643 - Team NAXJA/Petty Cash Racing "There's the troublemaker" - Craig Beck, BLM Ridgecrest Field Office . |
#12 (permalink) |
Window Licker
Member # 34948
Fuck...this is getting too complicated.
According to Mr. N, I should be able to use spindles from a '76 Chevy 1/2 ton. With the hubs from the '79 Bronco, correct? This is the '76 Chevy spindle on the left and an '79 Bronco spindle on the right. They don't look very similar around the base of the bearing inner bearing surface. Is this the right spindle for what I want to do?
#13 (permalink) |
Member # 43216
Maby I can add to the confusion. Working on a scout 44 front, need to match bolt patterns with my 9" rear. "Called Parts Mike" This is what I am using.
PM high steer knuckles, 71-76 chevy small bearing 6 bolt spindals "#dan706528x", ford bearings "tk lm501349 and tk lm603049" and seal "ns 4250" . 79 ford bronco hub and rotors, 75 gm k series caliper and support. Most of this was dropped off today so I havent tried to put it together yet. All numbers are off of the invoice from Parts Mike. Hope this helps. |
#14 (permalink) |
Moderator
Member # 20587
Dont confuse the seal surface for the inner bearing surface...
The bearings on the spindle are from a Ford 5 bolt hub. The Ford 5 on 5.5 hub, and the 73-76 jeep/GM 6 on 5.5 hub , use the same inner and outer bearings. Does this help you ? kris.
#15 (permalink) | |
Member # 1533
Here's the opposite thinking of your definition. If the ID is smaller with the same OD, the bearing itself has a larger surface area and thus larger. You say tomayto, I say tomahto.
#16 (permalink) |
Window Licker
Member # 34948
OK - thanks for the repplies! Think I got it worked out now...
The Ford hubs obviously had a small bearing spindle and therefore I need a small bearing Chevy spindle to match them. Easy enough. |
#17 (permalink) |
Window Licker
Member # 34948
OK, issue #2:
What outer shafts do I use. The chevy ones are about 1/4 - 3/8" longer than the Ford ones. Gut feeling tells me to use the Chevy ones. Any comments? |
#18 (permalink) |
Member # 20999
listen to the butterflies in your Stomach they are steering you right
