hack and tap slip yoke - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-21-2005, 08:10 PM   #1 (permalink)
Member # 44544
My friend and I are going to start a build up on his 92 jeep YJ. our plans are to do a spring over and shackle flip. he wants to put some 35's so we will probly put some toy axles under it plus a rear locker.
with as much lift as he wants I figure that we will need a SYE but the cheepest one I have found was $300. this build is on a real cheep budget $2500 for the hole thing so if we scrouge for parts we may be able to do this.
my real Q is what is needed to do a hack and tap on an NP231? if you can post some picks of what was needed to do it and the process.
thanks
mr.tech is offline   Reply With Quote
Old 03-21-2005, 08:12 PM   #2 (permalink)
Member # 20592
Send a message via AIM to gumbojeepyj Send a message via Yahoo to gumbojeepyj
you need the kit from rubicon express.
i run one and it hasnt let me down yet. but i did break a stock output shaft on a different Tcase before so its really not an upgrade in strength, just lets you use a cv shaft to reduce drivetrain vibes.
suck it up and get the HD SYE
Blake
http://www.lockitupoffroad.net
gumbojeepyj is offline   Reply With Quote
Old 03-21-2005, 08:18 PM   #3 (permalink)
Member # 44544
how much was yours and was it easy to install with the t-case in the rig or did you have to pull it. the reason I ask is because the is realy up tight about his rig and isnt even sure he vants to do a spring over.
PS I did a serch and came up with nothing so dont start with that shit.
Old 03-21-2005, 08:23 PM   #4 (permalink)
Member # 20592
well this should be in newbie section anyway but i guess since im here i'll help ya out.
i dont knwo the price but it is on RE's website. google is your friend.
second its easy to do in teh rig. to get a good straight cut, remove teh rear drive shaft adn make sure the tcase is in 2wd. or jsut take out both dshafts to be safe. crank the engine up and put the trans in gear. probably doesnt matter which gear. with the output shaft spinning use a cutoff wheel on a grinder to make the cut. put the flange on adn center punch that fucker as close to dead center as possible, then carefully drill and tap it.
Blake
Old 03-21-2005, 08:37 PM   #5 (permalink)
Member # 44544
ok I thought this would be a bit above nebies
Old 03-21-2005, 08:40 PM   #6 (permalink)
Member # 20592
not really, not on this board.
Blake
Old 03-21-2005, 08:48 PM   #7 (permalink)
Member # 44544
ok thanks for the help and I will keep that in mind for next time.
if any one has any pix I would be very interested.
Old 03-21-2005, 08:58 PM   #8 (permalink)
HeiserOilMotorsports
Po' riggity's Avatar
Member # 1515
Send a message via AIM to Po' riggity Send a message via Yahoo to Po' riggity
2500 bucks for SOA and SYE? You arent gonna do it right for that kind of money.. "RIGHT" includes regearing the axles, and you might as well lock them if you are going in there.. then you'll need bigger tires and different wheels...
Scott
HeiserOil Motorsports:
Crawlin' For Crohn's
Friends of San Bernardino National Forest (website not yet complete),
brought to you by Sbwinvps
Originally Posted by Alpine4x4 View Post
y'all know my flatbill hats make me the best desert racer out there!
Po' riggity is offline   Reply With Quote
Old 03-21-2005, 09:33 PM   #9 (permalink)
Member # 34672
i did a RE kit on my jeep about 4 years ago ran it for 2 years with 35's and welded spyders in the stock axles. i never broke it. and yes you can do it with the t-case in the jeep.
94yj on jackstand d44 589 xjyj waggy tube work
YjJon is offline   Reply With Quote
Old 03-21-2005, 09:38 PM   #10 (permalink)
Member # 44544
well i have a lead on some toy axles for $350
ring and pinion $180 for each axle
tires are $880
wheels free got them
shocks are $200
SYE ? price
mics. stuff $200
weld the rear free
drive shafts $250 each
total $2490
so as you can see we dont have the $ for an SYE
Old 03-21-2005, 10:19 PM   #11 (permalink)
Member # 37430
BTW performanceoffroadcenter.com has a HD SYE for $170. I have it and it works great. Now build that shit and tell us about it when its done...
MudTJ is offline   Reply With Quote
Old 03-21-2005, 11:12 PM   #12 (permalink)
lmagee's Avatar
Member # 21925
all this is fine and dandy, but how are you gonna run passenger drop yota axles with the stock driver drop t-case?
Lee
1992 Jeep XCYJ-8 102" WB
its stock
1995 Dodge Ram, the tow slut
its stock also
lmagee is online now   Reply With Quote
Old 03-21-2005, 11:57 PM   #13 (permalink)
Member # 20592
tires are $880
shocks are $200
SYE ? price
mics. stuff $200
weld the rear free
total $2490
plus two master install kits $200
Blake
Old 03-21-2005, 11:59 PM   #14 (permalink)
Member # 20592
Booyah! how the hell did i miss that?
how about a 3 piece driveshaft and two pilliow blocks
Blake
Old 03-22-2005, 08:47 AM   #15 (permalink)
Member # 44544
Damn.... I thought they were driver drop when I looked at them oh well I guess he needs to find some more $ for this build. LOL
Old 03-22-2005, 08:58 AM   #16 (permalink)
Member # 22393
Well if he has a 23 spline output shaft on the trans he could run a D300.
It'll take a lil drilling on the adaptor but then there is no need for a SYE and he'd only be out another $200 or so.
OlyWa
OlyWaXJ is offline   Reply With Quote
Old 03-22-2005, 10:16 AM   #17 (permalink)
Mo
Everyday is Tuesday.
Mo's Avatar
Member # 47
Mo is offline   Reply With Quote
Old 03-22-2005, 10:37 AM   #18 (permalink)
Member # 1515
yup, if you can get the toy axles, with 410's for cheap, run em, and buy a D300, and reroute the exhaust.
Scott
