1984 CJ7 coil wiring (or generic for that matter) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-10-2005, 12:04 PM   #1 (permalink)
Member # 19304
Send a message via MSN to gipper Send a message via Yahoo to gipper
84 CJ7 has two posts (plus the output to the rotor obviously). What do they go to? The connector has a light green wire and a red w/ white wire. The red w/ white was going to ground. The green was going god knows where. What should the two connections be? Does it matter if they are reversed?
For sale: 1984 CJ7 ... 4.10's, superwinch hubs, more.
gipper is offline   Reply With Quote
Old 05-10-2005, 12:43 PM   #2 (permalink)
Member # 3976
Send a message via ICQ to CJ5-Man Send a message via AIM to CJ5-Man
one side is positive. On 84 it'll have a resistance wire. You can use a regular 12v and use an inline ballast resistor if that wire is gone.
the other side is secondary coil. It goes to the ICM or to the points on the distributor.
CJ5-Man is offline   Reply With Quote
