dana 44 ring gear spacer - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-01-2005, 10:09 PM   #1 (permalink)
Grumpy_old_fart's Avatar
Member # 20147
Ive looked at many sites, called a few people, but as yet, I havent been able to find a ring gear spacer for a dana 44. does anyone know of one?
Empathy, apathy, sympathy.
Sympathy is between shit and syphilis in the dictionary.
Grumpy_old_fart is offline   Reply With Quote Quick reply to this message
Old 08-02-2005, 11:53 PM   #2 (permalink)
Member # 19446
Send a message via AIM to ?????
let me know if you find one.
????? is offline   Reply With Quote Quick reply to this message
Old 08-03-2005, 08:35 AM   #3 (permalink)
Member # 50632
before the flames get to high, Splain to us what you need to do with said spacer, If you are trying to fit 3.92 or lowwer gears where 3.37 or higher were you need to buy an new carrrier for them, Or let the place you buy the gears from know what carrier you have and most stock a thicker set just for your use in most common rattios.
HTH
Wayne
AllTech Motorsports
Fuel systems, shock work, and more
(951) 970-3399
Fox Shocks
ZukIzzy is offline   Reply With Quote Quick reply to this message
Old 08-03-2005, 09:01 AM   #4 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
I looked as well, some were made in the 80's but no one makes one anymore.
Mark
Old 08-03-2005, 05:17 PM   #5 (permalink)
Member # 19446
HTH
Wayne
I want to put my Rubicon front locker into Venezuelan XJ factory high pinion dana 44 front axle housing.
Old 08-05-2005, 11:17 AM   #6 (permalink)
Member # 50632
It will go but it is a 3.73 and higher (gear wise lowwer # wise) Carrier. you will need thicker gears from yukon if you want to go lower that 3.73. I bought 4.88s from randys and they went into a scout d44 with a 3.73 and higher Traclock.
Thanks
Wayne
AllTech Motorsports
(951) 970-3399
Fox Shocks
