going rate for a dana 60 front - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-10-2005, 03:01 PM   #1 (permalink)
Member # 11176
ok this is a little newbie so i posted here. is $1000 the going rate for a dana 60 front? i know theres all these stories about how someone got one for ten bucks from a los angelous junkyard but i mean for real.
"I calculated the odds of this succeeding verses the odds that I was doing something incredibly stupid... and I went ahead and did it anyways."
joefear7 is offline   Reply With Quote Quick reply to this message
Old 06-10-2005, 03:09 PM   #2 (permalink)
Member # 10894
Send a message via AIM to 46willys
Depends...
If every bearing and seal on the axle needs replaced. King pin or ball joint? Open knuckle? locker? Gears?
You can find a pretty decent one for 1000.
I paid 1500 for a running truck with a 60/14 bolt, TH400, NP205, running 350 And a steel flatbed thats in good shape.
46willys is offline   Reply With Quote Quick reply to this message
Old 06-10-2005, 03:27 PM   #3 (permalink)
Rockit's Avatar
Member # 6052
In your area, yes. Ford(HP&DS drop) will be a bit more than that.
Remember your not in an area where every neighbor is a farmer w/5 old farm trucks behind the barn.
'73 Bronco
Growing pile of parts. 4 years is long enough!
Rockit is offline   Reply With Quote Quick reply to this message
Old 06-10-2005, 03:32 PM   #4 (permalink)
Member # 27782
sometimes you can find them for less, like one that has been taken apart and the owner changed their mind/ran out of money, etc. But that $1000 is a good idea. I'd spend a little more to get one just so I don't have to replace all seals, bearings, etc. Some that you see for cheaper are rust buckets, so be careful and get pics.
Rob
Rob
[SIZE="4"][COLOR="Red"]www.rockcityfab.com[/COLOR][/SIZE]
KJ4Me is offline   Reply With Quote Quick reply to this message
Old 06-10-2005, 03:43 PM   #5 (permalink)
Member # 38563
doesnt boyce equipment have em' for around $1600 refubished
probably get one out of a m1009 or 8 (forget which one is the truck) with 4.56 gears
84' M1031 CUCV 37's, 8kW gen
Pietro is offline   Reply With Quote Quick reply to this message
Old 06-10-2005, 04:01 PM   #6 (permalink)
Member # 11176
I take it that the king pin ones are worth more than the ball joint ones?
I thought they were almost all open knuckle?
Old 06-10-2005, 04:43 PM   #7 (permalink)
Member # 27782
all the info you need:
http://www.pirate4x4.com/tech/billavista/60_front/
Rob
Rob
Old 06-11-2005, 12:50 AM   #8 (permalink)
Member # 45101
well, seems as though the going rate is almost always higher at a yard rather than someone selling it out of their backyard. I paid 750 for a '92 dodge D60 that just needs gear lube and calipers/pads. and got a free 14bff that needs a rebuild. a buddy got a chevy one for about half that, though, I did have to pick my nuts up off the ground after loading them into back of the truck - them sumbitches ain't light.
almost everyone agrees that kingpins are better than balljoints. the last time I checked w/ boyce they wanted around $2,500, +shipping, for a chevy D60F.
caddy powered '80's chevy... D60; 14FF-LL; 12K ramsey; 35's; parked for the winter.
[SIZE="3"]I agree! IntelliTXT is of no good .[/SIZE]
k10caddy is offline   Reply With Quote Quick reply to this message
Old 06-11-2005, 09:51 AM   #9 (permalink)
b454rat's Avatar
Member # 16536
I just got one basically for free, another I got for $85, then one for $40, HP for $100 and $125, and then a whole truck for $100. The most I paid for one was $500, and that one I have in my 89. I got that from a yard, and knew what they had. It was missing the hubs/rotors/brakes. Pretty much needed to be all gone over, though I was gonna do that anyway. I think I have a line on some more, military ones for a couple hundred I think. The kingpins are stronger and easier to crossover steering on, the reason they go for more. Also can get two newer style HPs for a couple bucks each I think. They are for sale if interested. An 89-90 and a ball joint, a 93 IIRC.
1999 GMC CCSB plans for 8.1 and SAS
b454rat is offline   Reply With Quote Quick reply to this message
Old 06-12-2005, 12:14 AM   #10 (permalink)
SeaBass44's Avatar
Member # 40
sure I think I can dig up $40-85 ............for each thanks! how about a flat $300 for the pair shipped, that way you make a few bucks seriously, he didn't ask how cheap ya found some, just asked "is $1000 the going rate for a dana 60 front?" Answer is YES
# 530.532.4529
TTC 2010 1989 BRONCO
-Awesome web development for your business.
SeaBass44 is offline   Reply With Quote Quick reply to this message
Old 06-12-2005, 03:51 PM   #11 (permalink)
wilf's Avatar
Member # 40928
Send a message via AIM to wilf
you bet your ass your gonna spend a grand on a dana 60 front escpecially if you go or call a salvage yard looking for a dana 60 they know whats up.
80cj5,115wb,360,th400,32 splined 4:1 dana 300,44"tsl's,xd9000i,fox coilovers,rockwell's.
"anybody can drive a jeep but it takes a real man to cut one up"
wilf is offline   Reply With Quote Quick reply to this message
