DuCaTi MoNsTeR
Member # 2931
is a 265/75/16 a 32'' tire or 31''?
265/75/16
255/85/16 285/70/16 which are actually 32'' in diameter? thanks
Amongst the best of the toyota vendors: Www.4wheelunderground.com Www.addictedoffroad.com Www.hellfire-fabworks.com |
Member # 18006
Take your pick, the tire size calculator I found says it is 31.64".
Tire Calculator I still can't relate to the metric sizes for 16" wheels either.
President Gettin' Off 4X4 Club '89 XCab - Dual Marlin w/4.70 in rear case, D60 Hybrid SAS, locked, FJ80 HP front, ....... '97 TJ - Atlas 3.8 TC, ARB's F&R, ...... |
Lost
Member # 6426
They can vary slightly form manufacturer to manufacturer. Pick which ones you are looking at and go to their web sight - they'll typically have OD listed. Remember the measurements are mounted on the recommeded rim width and inflated to max rated pressure (inflation pressure varies by LT load range or P-metric size)
Couple of YJ's without leafs. |
Member # 603
265/75R16 is "classified" as a 32 as mentioned above, which means it actually measures about 31". 255/85's & 285/75's are "classified" as 33's, meaning they spec out at about 32" ACTUAL diameter.
TEX
www.probog.com Thanks to: www.heiseroil.com Extreme Performance www.kmelectronics.com Bear Creek Auto Recyclers www.svrehorsepower.com |
