DTC's!!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-29-2005, 09:05 PM   #1 (permalink)
Kali_Jude's Avatar
Member # 37093
DTC's!!!
I have a 2000 silverado and the CEL just turned on. I scanned it and got a code po753. I dont have 1st gear or 4th, but 2nd and 3rd seem to work. Please help guys. thanks
88 4runner SAS, 40in iroks, longfields, 5.29's locked, dual cases, 4.7's in rear case, hydro assist.
Kali_Jude is offline   Reply With Quote
Old 06-29-2005, 10:33 PM   #2 (permalink)
Member # 40562
pull the pan and ohm the 1-2 shift solenoid. that's what the code is for. this solenoid controls the 1-2 and 3-4 shift valves, which provide 1st and 4th gear. spec is 19-31 ohms. I bet it's shorted. Good luck. DB
You're gonna have that!!
73 K10, lift, lockers, etc, etc, etc.
DSBANHEN is offline   Reply With Quote
Old 06-29-2005, 10:36 PM   #3 (permalink)
Member # 40562
If all that stuff is ok, you might try an ign switch. They get resistance internally and set codes. This one will default to 2nd if it fails. DB
Old 06-30-2005, 08:37 PM   #4 (permalink)
Kali_Jude's Avatar
Member # 37093
It was the shift solenoid and the trans wiring harness... Fewh... I thought it was going to be worse
