Welded 44 Question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-11-2005, 05:54 PM   #1 (permalink)
Member # 11257
Welded 44 Question
Just wondering if its possible to replace the welded spider gears to make an open diff again or would I have to replace the whole housing?
TIA
Give BLOOD!!! Mountain Bike.
YETI is offline   Reply With Quote
Old 07-11-2005, 06:04 PM   #2 (permalink)
Member # 43101
pita but not terribly difficult to do
Bandit0 is offline   Reply With Quote
Old 07-11-2005, 06:04 PM   #3 (permalink)
Member # 22345
you will have to replace the carrier and spider gears unless you can cut the spider gears apart...if you can, you can get away with replacing just the spider gears. It will be easier to just get a new carrier ad be done with it.
my weekend rides...
just another 1 ton CJ being towed by a '52 M-37.
Balsax is offline   Reply With Quote
Old 07-11-2005, 07:21 PM   #4 (permalink)
Member # 21888
If welded properly (gear to gear and to carrier) you wont be able to change em.
psychobilly is offline   Reply With Quote
Old 07-12-2005, 08:29 AM   #5 (permalink)
Member # 17313
X2
if welded proberly, you will have no reason to change them either..
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote
Old 07-12-2005, 09:29 AM   #6 (permalink)
Member # 11257
Thanks ya'll
