ford 8"/9" aftermarket centerpin - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-06-2005, 07:18 PM   #1 (permalink)
Member # 44595
Send a message via MSN to 1badb2 Send a message via Yahoo to 1badb2
i just got my 31spline mini-spool for my 8" and was curious if it'd be a smart choice to upgrade centerpin. currie says ill be fine with my 2.8 41:1 crawl and 33's...just lookin for more input. reason i didnt go full case is because i wanted to keep my 31spline shafts and nobody makes a 31spline locker for the 8". 9" mini-spool fits.
Rats get fat, while brave men die.
Spare parts? If you're shooting your weapon to failure, it means you're really good to have stayed alive through that much combat. You're not fucked, You're just down a weapon, go get another off of one of the many dead bodies you created
1badb2 is offline   Reply With Quote Quick reply to this message
Old 08-07-2005, 08:51 AM   #2 (permalink)
Member # 43101
moly xpins for the ford 9" are dirt cheap, around $6. you however have absolutely no need for one
Bandit0 is offline   Reply With Quote Quick reply to this message
Old 08-07-2005, 12:11 PM   #3 (permalink)
Member # 44595
where can i purchase those? and why do you say i have no use for one? i also heard the 8" and 9" mini-spool is alot stronger than say.. 7.5 or 8.8 because its once peice?
Old 08-07-2005, 03:08 PM   #4 (permalink)
Member # 17313
you would be a fool for not getting one, even with one, it's still the weak link..
last summer I went to "test" my new rear calipers on my truck. The brakes held, the cromomoly crosspin failed.. exploding the mini spoo, and carrier in the processes..
I spent the extra $100 on a full spool then, and have had zero issues.
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote Quick reply to this message
Old 08-07-2005, 03:10 PM   #5 (permalink)
Member # 43101
I run 36's behind a 170 hp motor with 60:1 final ratio on my el cheapo 28 spline ford 9" (weak) with a factory xpin and have had no problems with the rear. He's light and underpowered with small tires and I assume a factory driveline, if everything is set up right, a d-shaft u-joint will go long before that xpin. If you need one, any race shop can get you one for $15 and there were a handful of vendors on ebay awhile back sell'em cheap.
Old 08-07-2005, 04:06 PM   #6 (permalink)
Member # 44595
i have a Durasparkd 2.8 with headers and exhaust, TK4 transmission, BW1350 case, heavy duty d-shaft. Currie says my 1330 u-joint will blow before the centerpin does. im running 32x10.5 SSR's and i have a final ratio of 41:1. the reason i bought the mini-spool instead of full spool or locker is because the 8" runs same mini as the 9" and it allows me to use 31spline shafts instead of 28spline shafts. thats for the current input though.
