New 8.8 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-14-2005, 12:52 PM   #1 (permalink)
Member # 47229
New 8.8
I just put my new 8.8 in my garage It will take a little time to grind, build tabs and install. I'm trying to round up all the parts i'll need for the swap, will I need to change the master cylinder?? If you know of any other parts to get it would be helpful ??
thanx
P.S. 94 wrangler,4 pooper,sye,4 linkrear,35" x terrain's, and soon 8.8 rear.
[SIZE=5]BIG BOATS[/SIZE][SIZE=3],B[/SIZE][SIZE=4]E[/SIZE][SIZE=3]N[/SIZE][SIZE=2]T[/SIZE] [SIZE=3]J[/SIZE][SIZE=2]E[/SIZE][SIZE=5]E[/SIZE][SIZE=4]P[/SIZE][SIZE=3]S[/SIZE] [SIZE=3]AND[/SIZE] [COLOR=Sienna]DIRTY GALS[/COLOR]
octane4brains is offline   Reply With Quote
Old 08-14-2005, 01:00 PM   #2 (permalink)
Member # 51586
thanx
Just did this myself; Get the M.O.R.E. kit for the 8.8. They provide all the mounts you need to convert the 8.8 to your rig. YOu will need a U joint adapter, that is also provided by M.O.R.E., along with the emergency brake cable. Master cylinder does not need to be changed. Don't weld the tubes to the 3rd member; from what I understand, it causes leaks and other problems.
Roscoe P. Coltrane is offline   Reply With Quote
Old 08-14-2005, 01:19 PM   #3 (permalink)
Member # 47229
When you say dont weld the tubes, where on the tubes?? I,m currently running a trussed up D35 thats 4 linked. I really need to truss it up do to the amount of prerunning we do.
Old 08-14-2005, 01:25 PM   #4 (permalink)
Member # 47229
Oh yea did you have to get wheel spacers???
Old 08-14-2005, 09:59 PM   #5 (permalink)
Radbassist's Avatar
Member # 3076
I removed the proportioning valve in my Master cyl.....works OK....
1 warning on the 8.8 - - - - - > BE VERY CAREFUL WHEN WELDING ON THE TUBES! THEY WARP EASY!
Naw on the wheel spacers.
"In God We Trust, All Others We Monitor"
Radbassist is offline   Reply With Quote
Old 08-15-2005, 05:49 AM   #6 (permalink)
GSW
Member # 40411
Originally Posted by Roscoe P. Coltrane
....... Don't weld the tubes to the 3rd member; from what I understand, it causes leaks and other problems.
Could you elaborate? I've never heard any mention of this.
GSW is offline   Reply With Quote
Old 08-16-2005, 07:27 PM   #7 (permalink)
Pat98TJ's Avatar
Member # 23629
Send a message via AIM to Pat98TJ
Someone is taking you on a trip down the misinformation highway. Weld 4 each 1'' welds good and hot around each tube. Stu-offroad.com has a write-up I think.
The best deals are at [URL=www.offroadoverstock.com][SIZE=4][COLOR=Blue][B][FONT=Impact][FONT=Tahoma][FONT=Comic Sans MS][COLOR=Red]Offroad[/COLOR]Overstock.com[/FONT][/FONT][/FONT][/B][/COLOR][/SIZE][/URL]
Pat98TJ is offline   Reply With Quote
Old 08-17-2005, 10:57 AM   #8 (permalink)
Member # 41176
I stitch welded mine. No problems.
TJ
TJDale is offline   Reply With Quote
Old 08-18-2005, 12:58 PM   #9 (permalink)
Member # 19016
Here's the issue about welding the tubes to the pumpkin, to clear everything up.
http://www.4x4wire.com/jeep/tech/axle/ford8_8/
DevinB is offline   Reply With Quote
