Using Big Rubbers? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-14-2005, 11:47 AM   #1 (permalink)
Member # 51676
Arrow Using Big Rubbers?
How large of tires can safely be run at highway speeds?
oops... its a Blazer with a 118" wheel base..
Thanks..
kury is offline   Reply With Quote
Old 10-14-2005, 12:04 PM   #2 (permalink)
Member # 53743
Thats a pretty variable question. it depends on your rig. The crop sprayers drive safely with 68" tall tires. My 38.5" tsl's are horrible on the road though. I think they are safe, but they ride very rough.
jetboy is offline   Reply With Quote
Old 10-14-2005, 12:21 PM   #3 (permalink)
Moderator
geberhard's Avatar
Member # 5861
Same here, 38.5 TSL' son the road sucked, but have seen rigs running over 44" on the road (aside from fullsize trucks). I think the 40" range is the borderline.
geberhard is offline   Reply With Quote
Old 10-14-2005, 12:53 PM   #4 (permalink)
TEX
Member # 603
I too had a friend with 38.5" TSL's that sucked on the road. 38X12.50's aren't nearly as bad, though they're about 2" shorter & 20lbs lighter.
TEX
www.probog.com
Thanks to:
www.heiseroil.com
Extreme Performance
www.kmelectronics.com
Bear Creek Auto Recyclers
www.svrehorsepower.com
TEX is offline   Reply With Quote
Old 10-14-2005, 01:37 PM   #5 (permalink)
b454rat's Avatar
Member # 16536
Friend of mine just put 44s on his 95 Ram, does 70-80 with it and the only bitch is not enough motor.
b454rat is offline   Reply With Quote
Old 10-14-2005, 05:03 PM   #6 (permalink)
StockChevy's Avatar
Member # 37859
My 44's handle just fine even up to 75-80mph (don't normally go that fast though ).
I've got a friend with a little Toyota on 46's and it is plenty safe.
I'd say it all depends on your exact setup (especially steering, suspension, etc.), how balanced the tires are, etc.
StockChevy is offline   Reply With Quote
