Member # 38457
Figure out witch are the drain and fill plugs. Turn it right side up. Determine if it is driver side drop or passenger side drop. Pass=Chevy Driver=Ford and I don't remember dodge(driver?).
skullfuckery
Member # 29016
face bolt pattern figure 8 or circle 6, or is it a yoke, slip yoke rear, input spline count,
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
#5 (permalink) | |
Member # 2790
I would bet on it being an International with it having I on it.. Chevys will usually have 205c on them and Dodges will have 205D on them Fords will be Driver drop..
Russ hy_desert_4wheeler 46 Dodge WC15--67 M715--85 Jeep CJ10A--06 Dodge Ram2500Quad cab Cummins--94 Suburban--06 Ridgeline- |
#8 (permalink) | |
skullfuckery
Member # 29016
where the hell are you guys geting the letter from i have a chevy 205 plate in front of me and no "c"
skullfuckery
Member # 29016
fuzzy pic but it reads model 3 205, ratio 196, serial 2 16 78, assem.no. 465477
the 3 may have something to do with it, like it was the 3 verison, but thats just a guess.
#10 (permalink) | |
Member # 2790
my tag has the following info on it.. MODEL--205 D RATIO----195 Serial -----5 15 72 ASSEM.NO. 3491079
Here is some quick tech on the NP205, may help in identification. Stolen I am sure from somewhere. I had it in a notepad doc.
The GM NP205 has a passenger side front ouput, and is availible in fixed or slip yoke rear outputs. Input gear configurations are availible in 10 spline, 27 spline, and 32 spline. The 10 and 27 spline versions use drivesleeves to mate to the transmission. Stock front output configuration for a GM is 30 spline. The Ford NP205 has a drivers side front output, and is availible in a fixed yoke rear output. It has a 31 spline input gear, a 32 spline fixed rear output, and a 32 spline front output. Divorced Ford NP205's are availible. The Dodge NP205 has a passenger side front output, and has a fixed yoke rear output and a 32 spline front output. Input gear configurations are availible in Standard 23 spline, or HD Diesel 29 spline (Cummins Motor Applications. Both The 23 and 29 spline applications use drivesleeves to mate to the tramission which are not included in the base price. Divorced Dodge NP205's are availible.
Is:92 YJ 4.0 AX15 NP231 D30 D35 Will Be: 92 YJ 4.0 NP435 NP205 D60 14 bolt SOA waggy spr. [URL]http://www.rawsoftware.com/YJ-Mule/[/URL] |
#12 (permalink) |
Member # 113049
I got this divorced transfer case from my brother for free,and he didn't know what it was either.I'm trying to find out what it is so i can get a few parts for it.I'll put a few links of it on here.If someone has an idea of what it is, i would appreciate the help.
http://a894.ac-images.myspacecdn.com...f9a085c1c5.jpg http://a461.ac-images.myspacecdn.com...67ee0fc0f4.jpg http://a707.ac-images.myspacecdn.com...a0d604eb6a.jpg http://a620.ac-images.myspacecdn.com...abc55dae93.jpg http://a574.ac-images.myspacecdn.com...88f94e97a5.jpg Its real heavy,weighs 165 lbs. and it's all metal.Its a passenger side yoke to the front end. Last edited by jobjr79; 04-24-2008 at 08:48 AM. |
#13 (permalink) |
skullfuckery
Member # 29016
rocwell t221
60-68 chevy
#14 (permalink) | |
Member # 62866
hick
'97 XJ, D30, Ford 8.8, 35's '94 Mazda B4000, D35 TTB, Ford 8.8, 35's |
#15 (permalink) |
be cool, baby
Member # 17896
WRONG ![]() It is a NP202. Rockwell T221's look like this, from another Pirate post, actually:
Utah 4-Wheel Drive Association---Blue Ribbon Coalition---USA-ALL---Tread Lightly |
