metric EYE bolts 13mm Toyota seat bolt pattern - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-11-2005, 12:17 AM   #1 (permalink)
robrub00's Avatar
Member # 38381
I am Putting some 5 point harnesses anyOne Know where I can GEt some 13mm metric eye bolts. Now Don't say the hardware store Cuz Your wrong they go from 12 to 14 and skip over 13. Toyota uses this tread for There seat belt bolts. I cant find them anywhere I went to MR. metric a shop that specializes in metric bolts and no luck. Can anyone help/ make some? Or find A die To rethread some other ones. I was hoping to use stock locations scinced I have no welder but I will proBABLY END UP wELDING A PLATE AND A NUT iN THE FLOOR. sorry hit caps lock. thanks in advance. MAy be there is a hardware guru out there.
robrub00 is offline   Reply With Quote
Old 11-11-2005, 08:18 AM   #2 (permalink)
Member # 1418
Ya know .............. IIRC its standard thread (and npt at that), at least it is on the 4runners roll bar.........
Have you removed one of the bolts to check what it is??
Arizona Trail Riders ....... BRRRaaaAAAPPPPPPP
Kyron is offline   Reply With Quote
Old 11-11-2005, 06:55 PM   #3 (permalink)
robrub00's Avatar
Member # 38381
I removed a bolt I thought it was a 13 metric Your Saying it is a different tread What IS IT where can I get it? the seat bolts do fit in the roll bar
